Old 12-15-2007, 10:06 PM   #1
SteveJa's Avatar
Trader Rating: 17 (100%+)
Default motor tuning question....
lets say you tune your motor on say a day that is about 40~50 degrees... and you do it by the pinch test on the fuel line, and it runs good and you think you have a good tune... then you go run it on a colder day, say 20 ~30 degrees and it does not idle fast enough and dies, does this mean you have to lean it out to get the idle correct? or should you turn up the idle ?
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 12-15-2007, 10:33 PM   #2
Once your idle gap is set, you should never have to touch it again. It will always be low and high needles that need a tweak for ambient temperature changing.
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 12-15-2007, 10:38 PM   #3
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
just lean the low end about 2 hours and try it...if it needs a bit more go a 1/2 to 1 hour at a time, keep a close eye on the engine idle temps...
like soapy said once the idle gap is set you should never have to touch it again...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-15-2007, 11:05 PM   #4
UN4RACING's Avatar
Could he just simply put in a smaller restricter.?
UN4RACING is offline   Reply With Quote
Old 12-15-2007, 11:10 PM   #5
well not really...the carb has to be tuned for the different restricters also, so its hard to say if one of the restricters would be on tune...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-15-2007, 11:11 PM   #6
UN4RACING's Avatar
Ok thanks.
Old 12-16-2007, 09:53 AM   #7
SteveJa's Avatar
this is good to here.....
does anyone have the link that said what to do with your motor tune when the weather changes, it said some like this.... when the temp goes up you should (richen or lean) when the temp goes down you should (richen or lean) when it is more hummid or less hummid you should (richen or lean)
it was a really nice and cool page that had some good info on it
Thanks for all the help
HATCHER RACING !!!!
Impulse R/C
Old 12-30-2007, 12:06 AM   #8
Dave_x8's Avatar
Send a message via MSN to Dave_x8
i have seen that card you are talking about, there is a link to the page where it is on the forum somewhere, i just cant remember which topic it was under, ill see if i can find it again...
Dave_x8 is offline   Reply With Quote
Old 12-30-2007, 12:17 AM   #9
Dave_x8's Avatar
go into nitro off-road and skip to page 9 and you will see a topic saying motor tuning guide, click on it and its the second reply that has what you are looking for.
too easy mate
Old 12-30-2007, 01:25 AM   #10
vti-chris's Avatar
Guys the best thing to do is richen all needles a bit and retune.
That's what i do every time i go out to play or race.
It's very difficult to hunt down a tune when you don't know where you are at.
The "map" you are looking for won't tell you much...that's just the theory. In reality things work a bit differently...!!
Take just 3-4 minutes from your time at the field or track...warm the engine at rich settings and retune.
Most of the times i only richen up the high speed needle...warm the engine up by driving slowly...and then tune that needle...then i check for my idle and low speed needle which most of the times is spot on!!!
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 12-30-2007, 11:01 PM   #11
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
In general temp and humidity variations go like this:
Colder air is denser. Therefore you have to richen the needles.
Wamer air is less dense. Therefore you have to lean the needles.
Humid air is less dense. Therefore you have to lean the needles.
Dry air is more dense. Therefore you have to richen the needles.
I don't have a way to tell you how much to change for <x> degrees of change or <x> percentage of humidity change. What I know from my V-Specs is that they're not very sensitive in that regard. I might have to change up to a quarter turn when going from 70 degree air to 40 degree air. I've never felt the need to change tune due to humidity.
If you run at different tracks, you're going to want to retune anyway due to the different track layouts. Don't be afraid to just try needle changes to see what they do. Starting from pig rich on the high end needle and leaning down until the motor is REALLY singing (then backing off of that about two hours) taught me a LOT about my engines. I found out I have a 120-150 degree window (4-5 hours) where my engines run from good to great.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Tuning Question ChrisE Electric Off-Road 3 05-21-2007 04:49 PM
SH .28 Tuning question Nickmind Monster Trucks 3 04-13-2006 08:47 AM
Motor Tuning Question.... RCThunder Nitro On-Road 7 11-25-2005 12:48 AM
beginner questions re: car tuning and motor tuning! Captjono Rookie Zone 5 02-19-2005 11:01 AM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 02:01 AM
