Old 12-13-2007, 02:21 PM   #1
Default please help! engine question
I have a hpi firestorm and im trying to get it diled in. But when i start it the clutch is always engaged. Tryed turning the idle screw down and its still spining the wheels. Any help would help.
thanx
phenixx is offline   Reply With Quote
Old 12-13-2007, 02:26 PM   #2
didnt mean to post twice, mods can you delete?
Old 12-13-2007, 04:08 PM   #3
it sounds like the springs on the clutch shoes are too loose, i would put some 1.0 or 1.1 springs on. the springs are a little stiffer and will give you a higher rpm engagement
jombo is offline   Reply With Quote
Old 12-13-2007, 04:24 PM   #4
Do you think it should be still at idle? Ive only had it for a few days. Ive tuned the high speed needle, but the manual says not to even touch the low speed needle. So could the low speed needle be the problem???
Old 12-13-2007, 04:37 PM   #5
brad996's Avatar
is the motor idling really high and when you rev the motor does it come down to and idle or does it hang at a fast idle and then slowly come down
brad996 is offline   Reply With Quote
Old 12-13-2007, 04:50 PM   #6
The idle isnt to high. Even when i turn it down to a lower idle the wheels want to turn. I have to put my foot in front of the car so it dosent take off. I havent even messed with the low speed yet eather, just the high speed and idle needle.
Old 12-13-2007, 05:31 PM   #7
brad996's Avatar
you could have a broken clutch spring thats what I would check 1st
Old 12-13-2007, 05:40 PM   #8
^^ Is this commin??
Old 12-13-2007, 07:22 PM   #9
it could be your lsn too lean, try the pinch test . start the truck and after it warms up a min or 2 pinch the fuel line about an inch away from the carb. if it dies instantly its too lean if it takes about 4 or 5 seconds its fine. but i still think its the springs, the savage has the same problems. when i changed my springs i never melted another sput gear because the clutch wont engage unless it was at a high rpm.
Old 12-15-2007, 11:38 AM   #10
Thanx for all the help guys. Problem fixed!!!
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 08:21 AM
.21 Engine Question roylo Nitro Off-Road 7 09-03-2007 10:04 PM
General .21 engine question as well as one specific to Sportwerks .21 Pro engine Cain Electric Off-Road 0 10-23-2006 10:19 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
Serious gas engine question. pro engine tuners look here Ron Nitro On-Road 28 11-13-2001 03:27 PM
