Old 12-11-2007, 12:18 PM   #1
plecofish's Avatar
Send a message via Skype™ to plecofish
Default Hopicomponents: the universal diff. solution
Here I am to introduce you a new hop-up for both our off-roads models, buggy and truggy. Born out of the mind of Domenico Mezzabotta, an Italian modeler and devised in order to answer the problems of bindings and fast wear that plagued the differentials of its 8ight...may be of everybody’s 8ight!!!
Domenico has put “bearings” in the outdrive cup pivots, a not easy job considering parts small sizes, but not impossible… how? By using high quality steel.
The kit is made by Hopicomponents and its under patent pending.
Each kit contains two special diff-outdrive cups made by high quality steel, produced with high precision CNC machine tools and many steel rolls of 1 mm diameter each one.
When Domenico has decided to begin this adventure, he phoned
me asking if I could take care of the reliability and durability tests.
He sent me a set of prototypes so I could start my job!
Well, I treated them badly for one month both on buggy & truggy and now I can
tell You … those stuff is extremely reliable and give You a great increasing on overall traction performances: I never had failures of the product and the wear is not still percepibile.
Which are the PROs?
-remarkable low friction between diff housing/ring gear and the outdrive cup pivot
-long lasting of the new outdrive cups made by high quality steel
-less stressed areas on satellite and planetary gears, they works firmly
-lower temperature when differentials works
-less alteration of the viscosity of the silicone oil thanks to minor overheating of the case
-a better torque distribution on the three differentials
How to install the kit?
Simply put a film of high quality graphite grease on the outdrive cup pivot, then insert 15 rolls for each cup. The outdrive cup pivot is ready for being inserted in the diff housing and/or in the ring gear.
this is what’s happened to me in
The A-Main of the Italian Truggy Nats....
It will not happen any more!
Currently only the kit for Losi 8 is on sale, but Domenico is working on many different brands: so You will find in short time more kits for Jammin/HN, Hobao, Kyosho, etc.
You can buy the kit directly from www.hopicomponents.com.
Notice that the product has been positively reviewed on the Italian RC magazine
"TRUE MODEL", in the December 2007 number.
Cheers from Italy,
Maurizio Conti
plecofish is offline   Reply With Quote
Old 12-11-2007, 02:04 PM   #2
That's a great design. I was just talking with a friend the other day about the problem of metal on metal contact on the diff cup/out drive.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 12-11-2007, 02:09 PM   #3
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
I like the idea! How does the internal seal for the diff still work? Is the o-ring riding on the needle bearings, or on the shaft? Has there been any breakage of the very narrow shaft where the needle bearings sit?
SkarTisu is offline   Reply With Quote
Old 12-11-2007, 02:49 PM   #4
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I fail to see how it will fix the issue of the cross pins wearing out the cross pin slots. Also, is there any type of cage to keep the needle bearings spaced? Otherwise they will just bunch up and cause more problems...
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 12-11-2007, 06:05 PM   #5
Vigilante212's Avatar
Using a metal diff housing would have probably prevented that blown diff. its an interesting design, but like rezenclowd3 said how do you keep the bearings from bunching up?
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 12-11-2007, 06:10 PM   #6
HaulinBass's Avatar
IMO using block attached to the crosspins that slide into the pinslots in the diff cups is a much simpler idea.
also arn't needle bearing prone to fail if they stop moving.
HaulinBass is offline   Reply With Quote
Old 12-11-2007, 07:23 PM   #7
Trader Rating: 26 (100%+)
alloy diff housings and cross pin blocks add a lot of un-needed weight to your drivetrain, they are ok for MT's or bashers, but for true race kits they are about the worst thing you can do,
the only thing I wouldn't like about this set up is putting all those needles together, I would need the kit to come with 4 or 5 extra for the ones I lost on the floor, lol
bobf24 is online now   Reply With Quote
Old 12-11-2007, 08:16 PM   #8
Rocket42's Avatar
I think this was an excellent idea, and It could be even better with the feedback posted here. People have mentiond that the needle bearings laid loose like that could bind. Maybe it would be better for him to cut 6 precision half circle cuts into a stock outdrive and place the needle bearings in that, so he would be using the outdrive as a race as well. then he would also only need 6 needle bearings instead of 15 and it should perform the same.
Rocket42 is offline   Reply With Quote
Old 12-12-2007, 03:47 AM   #9
plecofish's Avatar
Im doing more pics, and I'll post them soon, to explain You all better.
Cheers from Italy,
Maurizio Conti
Old 12-20-2007, 04:06 AM   #10
plecofish's Avatar
here below few images about the packaging of Losi 8 kits with bilingual
instructions
Cheers from Italy,
Maurizio Conti
Old 12-20-2007, 06:34 AM   #11
lowey79's Avatar
There wont be any binding with loose needle rollers.... Automotive manufacturers have used them in drive shaft universal joints for the past 40-50 years without any problems....
lowey79 is offline   Reply With Quote
Old 12-20-2007, 09:14 AM   #12
Will someone sell them in the USA?
cota348 is offline   Reply With Quote
Old 12-20-2007, 11:32 AM   #13
plecofish's Avatar
within few days, paypal payment will be available too,
I have just discussed it by phone with Domenico
And I am doing an installation tutorial with my camera, so.... stay tuned
Mugen & Kyosho kits are still on track testing
Cheers from Italy,
Maurizio Conti
Old 12-20-2007, 11:39 AM   #14
GenReaper's Avatar
Send a message via MSN to GenReaper
Good idea but IMO you will need a better finish on the lathed section of the cup to get rid of those chatter marks, polish them up and they would last alot longer, or tell your mate to sharpen his cutting tool.
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
Old 12-20-2007, 11:49 AM   #15
WheelNut's Avatar
Send a message via MSN to WheelNut
The Losi has aluminum inserts in the diff cups for the diff shafts doesn't it? That is why they wear right? Other brands use steel though. I know that I have not noticed any excessive wear through an entire season of running my Xray car.
•Brad Comis
WheelNut is offline   Reply With Quote
solution to not get ripped off SRBMOJO Buyer/Seller dispute and Feedback discussion forum 11 11-22-2007 12:04 AM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 10:11 PM
Better battery solution for TLT-1 ? Lonestar Monster Trucks 2 10-28-2004 05:19 AM
Sugar Solution Mixture? DCR1TWO Nitro On-Road 18 01-27-2003 05:08 PM
