Old 12-07-2007, 04:30 AM   #16
Send a message via MSN to DirtRacer
PRO:
RollingDist46
extreme sports and more....
www.myspace.com/m1urathanedist46
www.myspace.com/renegadebearingsdist46
DirtRacer is offline   Reply With Quote
Old 12-07-2007, 04:32 AM   #17
these are pics i found in the links, official pics will be up when recieved.
RollingDist46
Old 12-07-2007, 04:41 AM   #18
STR8 in Action: http://www.youtube.com/watch?v=NH4PKPnt5mM
RollingDist46
Old 12-07-2007, 04:56 AM   #19
http://www.redrc.net/2007/03/hobbytech-str8-pro-buggy/
more info and pics
RollingDist46
Old 12-07-2007, 02:42 PM   #20
just recieved the pics of the RTR and PRO and the ones you see above are the official buggies.
RollingDist46
Old 12-07-2007, 03:11 PM   #21
nobike's Avatar
Trader Rating: 147 (100%+)
cool buggy...............
nobike is offline   Reply With Quote
Old 12-08-2007, 07:29 AM   #22
Default dual posting
removed
Poinas2 is offline   Reply With Quote
Old 12-08-2007, 07:29 AM   #23
I have experience with both the RTR and Factory. Both are well capable buggies. We've had some track-time with both and they seem to perform well. Good power-on steering, good on jumps, OK in rough parts etc. Not that agressive to turn in corners but as said better with power on. However we are still working on the setups so we might find some tricks. However both versions tends to respond well on changes.
Factory V2 comes with 7075AL radio plate, shock towers, front plate etc. (like in pictures) and not the CF ones which are option-parts. Also the chassis is hardened 7075. There's also hop-ups like lightened chassis, AL center diff.mounts etc.
RTR is pretty solid platform as well. Different shocks and lower grade AL parts. Also CVD's only in front. Radios are not top-notch but that's what you could expect. Servos are OK, especially the steering servo is up to the task (9kg) so just different TX/RX combination and you are done. Factory shocks and shock towers would be a recommended upgrade as it gives more adjustability and the Factory version shocks are IMHO better.
I think the e-clips are the somewhat weak point but nothing you can't live-with. There should be upgrades coming that brings captured hinge-pins. Also the 25deg. front hub requires modified front arms to give all benefits.
EDIT:
Forgot to mention that also the Factory Buggy comes pre-assembled. In Factory you need to add diff.oils and build shocks. Also here is a set of pre-glued tires you can use to settle the diffs and maybe broke-in your engine. Tires are with pretty soft inserts and the sidewalls are bit high so not much of a use in racing.
Old 12-08-2007, 08:00 AM   #24
If a pro version is to be released in the US it should be fully loaded minus tires/rims. I know that many people can't stand getting a buggy and then having to spend another $150 for option/hop up parts. Just provide them in the first place.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 12-08-2007, 08:44 AM   #25
Well speaking of the Factory I think it really does not need the provided options in performance vice. For sure the milled chassis is a bit lighter and the Al diffmounts are a bit more solid but mine is w/o those and I can't see it lacking much.
Old 12-08-2007, 08:49 AM   #26
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i just cant see why a pro level buggy should have factory hop ups...it seems to me like hobbytech is fishing for more money by selling hop up to those that buy the pro model...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-08-2007, 08:50 AM   #27
if it is pro level race worthy out of the box then why make and sell factory hop ups???
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-08-2007, 09:07 AM   #28
Well I believe you should ask that from basically every company making Racing Buggy or Truggy
Old 12-08-2007, 09:20 AM   #29
But not the Losi 8, and that's one of the reasons it's the number one selling buggy now. There's no need for a bunch of hop ups. It's about time the rest of the industry learns from Losi's success and listens to the people.
Bruce Edwards
Thanks to:
Old 12-08-2007, 09:31 AM   #30
KyLayfield's Avatar
Trader Rating: 86 (99%+)
They call them optional parts for a reason. You really don't NEED them, but if you WANT them, there you go. Hobbytech is just doing the same.
Losi sells hop-ups also; engine mounts, chassis braces, steering plate, steering knuckles, c-hubs, etc..
http://losi.com/Products/RelatedPart...s&SubCategory=
KyLayfield is offline   Reply With Quote
Hobbytech Straight Factory V2 vti-chris Nitro Off-Road 7 02-08-2008 06:15 PM
Hobbytech 27t stock motor Wilabidd Rookie Zone 0 02-06-2008 11:13 AM
New STR8 Factory V2 buggy vti-chris Nitro Off-Road 20 01-20-2008 11:11 AM
Losi 4wd prototype + BJ4 prototype at Worlds cartmen34 Electric Off-Road 32 08-24-2005 08:13 PM
Hobbytech rims TRF-Powered Electric On-Road 6 09-13-2001 06:47 PM
