Old 12-04-2007, 07:21 PM   #1
Chuck67's Avatar
Trader Rating: 36 (100%+)
Default Advice on an OS MAX .21 RG
I have an older OS MAX .21 RG I dropped it into our Losi 8 Buggy. Question is which pipe would be better suited for it a JP-1 or a JP-2?
Thanks,
Chuck
Chuck67 is offline   Reply With Quote
Old 12-05-2007, 06:40 AM   #2
I used to run an 053 and have also run a jp-1 back in the day and it sreemed with either one but that was on a small tight technical track. The rg's seem to have a ton of bottom end grunt. You would probably be fine with either of the ones you listed depending on the track conditions.
shockripple is offline   Reply With Quote
Old 12-05-2007, 06:52 AM   #3
Trader Rating: 21 (100%+)
Send a message via AIM to shawnyd Send a message via MSN to shawnyd
i like the jp-2. better top end on an engine that lacks top end from the factory. And i run on a track with a mile long back straight, top end matters where i run...
shawnyd is offline   Reply With Quote
Old 12-05-2007, 08:44 AM   #4
Trader Rating: 15 (100%+)
Chuck67:
If your running on a track with about only 100-110' straight run a 13 tooth CB. If your running on a track with a longer straight then use a 14 tooth CB.
Also run either aluminum or carbon shoes with 1.0springs.
The only pipe to use is a Nova 086 with a regular header!
With these combos you can run with anything out there.
7.5man is offline   Reply With Quote
Advice... JR V Nitro Off-Road 5 10-19-2007 11:54 AM
need some advice xrs_wtf Nitro Off-Road 7 10-02-2007 01:28 AM
New to RC need advice ZeroAccess Electric On-Road 13 09-02-2006 02:00 PM
1/8th advice stephen_p Nitro On-Road 11 02-24-2006 06:04 AM
XRAY T1 Evo 2: Building Advice, or setup advice Carbon_Fibre3 Electric On-Road 9 01-03-2003 01:44 AM
