Old 12-03-2007, 06:42 PM   #1
jgtruggy's Avatar
Default Engine dies
Once I get my mach 427 started I'll let it warm up. After about 2min. I try to give it gas and it dies. I restart and drive it with no problems and good temp readings. I'll bring the 8T back in and let it just sit and idle. When I try to go again it will die. Does this mean my tune is off? Or maybe to much gas is sittin in the engine or carb causing it to die? Thanks for any advice
Losi SCTE
Tekin RX8/Tekin Pro-4 4000kv
Topgearhobbies.com
jgtruggy is offline   Reply With Quote
Old 12-03-2007, 07:06 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
probably a lil too rich on the bottom ,
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-03-2007, 07:12 PM   #3
jgtruggy's Avatar
So I should just adjust the low end a little leaner? Sounds good. Thanks Houston. It seemed odd but is running so well. The beauty of fine tuning
Losi SCTE
Topgearhobbies.com
Old 12-03-2007, 09:39 PM   #4
Maikaitan's Avatar
i think the low end is a little rich... you can left it as it is as a little richer on the low end saves the bearings... lean bottom is usually the one that kills engines...
some clarification first... how long did you leave it to idle? if it's like less than 20 secs, then should lean down the bottom end, or turn in the idle screw a little...
did you full bore the engine just after it idles? i'll blip the throttle if it idles for a while to clear the engine....
2 cents...
HobbyThingzBlk 201-E, Tampines Street 23, #01-118, Singapore 520201. Tel: 65-67828311, HP: 65-97465015. www.hobbythingz.com, team@hobbythingz.com
Regional Sole Distributor for Team Associated, Orbit Electronics, J Concept and PolyButler. Dealer for Tamiya, Kyosho, GS, Proline, Byron, Os Engines, RB, Futaba, Sanwa, KO.....
Please note that we are closed every Tuesday and P.Holiday. Hours are: 12pm-9pm.
Maikaitan is offline   Reply With Quote
Old 12-03-2007, 09:56 PM   #5
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
It sounds as if the bottom is a little on the rich side. Lean the bottom out about an 1/8th of a turn. Then run the car, clear it out and let it sit for about 8-10 seconds. Once it has set for 8-10 secs floor it, if it goes but bogs then lean it another 1/8th. Then try it over again. After sitting for about 8 or so seconds and you floor it, the car should come off of the line pretty strong but not insanely. This should pretty much get you in the ballpark. If you need more help you are more then welcome to PM and I will answer everything that I can.
MB-
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
Old 12-03-2007, 11:32 PM   #6
jgtruggy's Avatar
Thanks Black and Maikaitan. I'll try it as soon as the rain stops. Maybe march I live in Portland OR. No indoor tracks here.
Losi SCTE
Topgearhobbies.com
Old 12-04-2007, 08:01 AM   #7
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Yeah... what Black said. Note that MOST buggy engines (when tuned properly) won't idle well for more than about 8-10 seconds. If it idles "forever" and you aren't idled up too high, it is probably too lean on the bottom. After about 8-10 seconds it SHOULD start to load up (with too much fuel, i.e. flood...) For some reason though the RB engines are the exception to this... I don't know about yours, I'm not familiar with that engine.
If you have it set lean enough on the bottom to idle for a long period of time, you won't be able to get the top lean enough for peak power without getting the temps too high! It is all a compromise.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 12-04-2007, 11:02 PM   #8
houston's Avatar
hey jg who are you ? i live in portland and a very well known racer in the area , maybe i will hook you up with a tune and some advice when we meet !
later , monty
Old 12-05-2007, 06:22 AM   #9
Trader Rating: 33 (100%+)
I dont know if i agree with that.. simply because, an engine with a fatter bottom, has too much
fule in the crank, causing the piston to have to compress more fuel than optimal, means more wear on the parts.. it is better to have a slightly lean bottom end, and a slightly rich top end.. simply because you are rarely on the low end needle enough to really cause alot of damage.. as soon as you get bout 1/8th pull on the trigger.. you move off the bottom end needle, and the top end/mid takes over..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 12-05-2007, 06:27 AM   #10
direct from the Sirio website
Normally you will not damage your engine if you are running with:
the high speed needle valve set TOO RICH and
the low speed needle valve set TOO LEAN
The opposite can be very dangerous for your engine
Daniel Grobe
Sponsors:
Old 12-05-2007, 09:28 AM   #11
jgtruggy's Avatar
Thanks for that input
Losi SCTE
Topgearhobbies.com
Old 12-05-2007, 10:43 AM   #12
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Read this article by the late Ron Paris. It's an excellent paper by one of the best engine tuners in the world....
SkarTisu is offline   Reply With Quote
Old 12-05-2007, 11:00 AM   #13
jgtruggy's Avatar
Very good article. I will keep this in my file from now on. Thanks StarTisu
Losi SCTE
Topgearhobbies.com
Old 12-08-2007, 04:27 PM   #14
jgtruggy's Avatar
later , monty
Houston, hey it's JG. I PM'd you a few days ago. I live in Gresham. PM me whenever
Losi SCTE
Topgearhobbies.com
Engine noise when it dies... pirate252 Monster Trucks 2 12-31-2005 02:05 AM
Engine dies after full load... megasig Rookie Zone 10 05-06-2005 05:08 AM
engine dies tjrcs Nitro On-Road 1 05-16-2003 11:23 PM
engine dies Smoke Rookie Zone 2 04-14-2003 06:51 AM
engine just dies RaTTuS Nitro On-Road 6 01-19-2003 09:34 PM
