Old 12-04-2007, 09:21 AM   #31
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Originally Posted by Maikaitan View Post
the only way is to open the engine back plate to count the bearings... another tell tale sign is the packaging... the updated one should come in a special bubble wrapping the engine... the old version comes in foam cushioning the engine in the box...
hope this helps...
Not quite correct. The "07" V-Specs have an extended ridge on the bottom of the crankcase that runs all the way to where the front crankshaft bearing sits. That ridge only runs halfway between the front and rear bearings on the "06".
Both versions have the same bubble wrap packaging inside the box.
Also, the 06 V-Specs have an 8 ball rear crankshaft bearing, where the 07's have a 9 ball rear bearing.
SkarTisu is offline   Reply With Quote
Old 12-04-2007, 09:25 AM   #32
SkarTisu's Avatar
Here's a picture of an 07 V-Spec. Notice the ridges on the bottom which go all the way along the bottom of the crankcase.
Old 12-04-2007, 09:46 AM   #33
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
shell out a little more money and go for the C6BBT (turbo plug).. very very good engine... just remember to use o'donnell 77T plug to cure the flame out problem... the piston sleeve fit is also very tight... MUST do a proper break in with heat cycles and dun be afraid to run it a little hotter... 130ish degree c is fine....
BTW its the C6BB7T not C6BBT. Well, I believe the C6BB (non-turbo) is no longer produced, but still sold if the resellers have not sold out. I have not seen a place to buy a non 7T for quite a while. But yes, proper break-in is essential on any race motor. On my standard C6BB I already put the 7mm venturi in for most race occasions (which the 7T comes with stock) but I do not believe I need any more power at this moment. (I really don't think anyone but the pro-level racers need this power, but its always fun)
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 12-05-2007, 03:34 PM   #34
Thanks for all the advice, I really appreciate it. I got the v- spec only problem is it is a 06 version I didn't understand the ridge until I compared the two. Is there anything I should do like change the bearing before it goes or just keep a close eye on it.
clebo3 is offline   Reply With Quote
Brushed Mod Motor Choice? Mini_Me Micro and Mini Scales 36 12-20-2007 10:23 PM
Best choice for Motor BKMongoose Electric Off-Road 5 10-04-2007 09:35 AM
b4 motor and battery choice??? TH691 Electric Off-Road 3 04-11-2007 09:18 PM
how to choice a electric motor bhakj Rookie Zone 5 06-18-2005 10:58 AM
Motor Choice Ridge_Racer Rookie Zone 4 02-17-2005 12:44 PM
