Old 11-29-2007, 07:48 PM   #1
SteveJa's Avatar
Trader Rating: 17 (100%+)
Default ceramic vs. stock motor bearings..
how much longer if any does the ceramic last over the stock bearings... or do the stock bearings last longer. This is for motor bearings, rossi.....
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 11-29-2007, 10:27 PM   #2
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I have had way better luck with normal steel bearings. The ceramic bearings spin better, but pretty much every engine bearing failure I have ever had has been a ceramic bearing.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 11-30-2007, 02:27 PM   #3
kaotickc's Avatar
Trader Rating: 43 (100%+)
+1 here also on what he said.
kaotickc is offline   Reply With Quote
Old 11-30-2007, 04:41 PM   #4
SteveJa's Avatar
oh this is great... i should have asked this before i bought a bunch of bearings... i always do things backward.....
maybe i should send them back before i put them in.....
HATCHER RACING !!!!
Impulse R/C
Old 11-30-2007, 04:58 PM   #5
SteveJa's Avatar
also what brand should I get boca ???
thanks
HATCHER RACING !!!!
Impulse R/C
Old 11-30-2007, 05:27 PM   #6
mugenb46's Avatar
What brand of ceramics have you had failier from? i have used ceramics for quite a while and they have always held up very well, to be honest i can't ever remember having to replace a rear bearing, fronts yah but i replace them with ceramics and they last pretty good, but most fronts seem to leak after a good bit of time.
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 12-01-2007, 12:29 AM   #7
Boca and Novarossi.
Old 12-01-2007, 12:36 AM   #8
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Some engines benefit a lot from ceramics. Like OS V-Specs. I put TKO ceramics in mine from the start and have never had any bearing issue at all. With the steel bearings, you're mainly concerned with not sliding the ball along the race where it runs. This can happen if the cage inside the bearing gets gunked up with thick oil. As long as that doesn't happen, and you don't death-rev the motor (especially when it's cold) you should be fine.
SkarTisu is offline   Reply With Quote
Old 12-01-2007, 03:55 AM   #9
imaxx21's Avatar
Send a message via AIM to imaxx21
put a TKO ceramic in and dont look back
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 12-01-2007, 04:08 AM   #10
Trader Rating: 38 (100%+)
Amen, good info.
In my biz we install ceramic bearings. I've used a couple different brands and have only had one failure from, believe it or not a TKO.
From what I've seen, all front bearing will eventually leak. They have a lifespan. Considering they have pressure behind them and a moving shaft which may move not only in a rotation movement but may flex, thats alot of "stress" on a bearing.
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 12-01-2007, 05:06 PM   #11
Peter Martin's Avatar
If any TKO engine bearing ever has a problem please save it and contact us. We are bearing engineers and will replace any bearing if it is a manufacturing problem etc.
Peter Martin is offline   Reply With Quote
Old 12-01-2007, 06:51 PM   #12
as nice as that would be it will still suck if the bearing take ur $500 modified motor with it but still least u have pride in your product and backit up
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 12-01-2007, 06:52 PM   #13
houston's Avatar
Trader Rating: 91 (100%+)
hey peter , did you guys get your new batch of 14.5x26mm ceramic bearings yet ??
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-01-2007, 07:16 PM   #14
Bigedmond's Avatar
Trader Rating: 18 (100%+)
I just put TKO ceramic bearings in both of my OS vspec's.
Bigedmond is offline   Reply With Quote
Old 12-01-2007, 08:01 PM   #15
Well, thats good to hear about the bearing. But what about the motor it destroyed?
I've never seen an inner race "chip" like that. It destroyed the rest of the engine taking part of the con-rod and sleeve...
As a small business owner I can't afford a failure like that. A 25 dollar part taking out a 300.00 dollar engine....
I'm not bashing TKO. I know failures can happen anytime any place...
PM sent...
HPI - Blitz
WTB: CERAMIC BEARINGS dynasty R/C Items: Wanted to Buy 0 12-12-2007 10:40 AM
Ball Bearings in a Stock Motor - why aren't they legal? or8ital Electric On-Road 60 04-24-2007 10:21 AM
Ceramic bearings for my T2 Got Xray? Australian Racing 33 08-21-2006 12:14 AM
Ceramic Bearings redlion Electric On-Road 5 04-21-2006 06:39 PM
Changing ball bearings in Tamiya Super Stock Motor TZ uniquexme Rookie Zone 4 04-03-2006 10:33 PM
