Old 12-01-2007, 08:45 PM   #16
SteveJa's Avatar
Trader Rating: 17 (100%+)
I did have a ceramic fail, that is why I started this.... one of the balls broke 3 or 4 little pieces... I sent it back to Amain along with the other 5 new ceramics I just got for an exchange for steel bearings..... the few people I have talked to told me the same thing (that the ceramics do not last as long and they will fail before steel) so I am not out but $4 for shipping, so now I have steel boca bearings on the way....
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 12-02-2007, 02:26 PM   #17
houston's Avatar
Trader Rating: 91 (100%+)
i have used alot of different bearings in my engines and have found most tko products to be great !! no failure ! i have used 14x25.4mm C , 14x25.8mmC , 7x19x6mmXC front bearing . i have not used 14.5x26mm C (plus 21 size) cause when i checked the bearing out at the hobby shop it had more play in the bearing than any i had ever seen , even worn out ones !!! and i am not putting that in my engine !!! the performance results are vast , smoother , higher revving , lower temps, less harmonic vibration resulting in less clutchbell bearing failure. personally i take my engines apart and clean them after every 3/4 to 1 gallon of fuel ran through the engine for close inspection the boca ceramics are good , and the boca steel bearings are better than most steel bearings on the market , these are what i recommend for 14.5x26mm applications
later , monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-02-2007, 02:38 PM   #18
mremtr's Avatar
Well guys this is how bearing life has been for me , I seem to get about 12 gallons of fuel through the stock rear bearings and then replace them with TKO ceramics ,the fronts all the stock ones only lasted maybe a gallon before the engine started to act up , I changed them out for Double Sealed bearings
and have never looked back PERIOD !!! You can leave the second seal on them , just get high temp high speed bearings , I forget the specs as it has been 3 years since I have changed them !! What I do know is they are made in England and have brown colored seals . They work PERFECT! As for the rear bearings all my engines take the 14mmx 25.4 bearings ,as of right now I don't have any with ceramics in them ,but that is about to end asI am going to put ceramics in my 421B for next season.
mremtr is offline   Reply With Quote
Old 12-02-2007, 08:02 PM   #19
houston's Avatar
the boca front 7x19x6mm front bearings come double sealed . havent had the best results with leaving both seals on the front bearing though ! the bearing doesnt seem to get enough lube while engine is running and starts harmonic vibration which causes bearing to spin slower than crank , leaving a rust type residue and scratched crank not advised
later , monty
Old 12-02-2007, 10:09 PM   #20
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
On all the Boca Bearings with front and back seals, I pluck out one seal and run them open on the back. They will get the lube needed, and I can't see leaving them sealed with Kluber grease alone. The new Nova double front sealed bearings look trick though.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
WTB: CERAMIC BEARINGS dynasty R/C Items: Wanted to Buy 0 12-12-2007 10:40 AM
Ball Bearings in a Stock Motor - why aren't they legal? or8ital Electric On-Road 60 04-24-2007 10:21 AM
Ceramic bearings for my T2 Got Xray? Australian Racing 33 08-21-2006 12:14 AM
Ceramic Bearings redlion Electric On-Road 5 04-21-2006 06:39 PM
Changing ball bearings in Tamiya Super Stock Motor TZ uniquexme Rookie Zone 4 04-03-2006 10:33 PM
