Angling your tires?
#16
#18
you guys (you know who you are) are a bunch of douche bags. i didnt say i didnt care about my car in general, i just dont care about EVERY little tiny, insignificant angle and adjustment i can make. i asked a very very, very basic question, and all i wanted was a basic answer.
/thread
/thread
#19
Your the only one here that gets enough info that you don't have to ask simple questions. The answers are right in your face but you still like to post dumb questions. Read the information provided and stop wasting everyone's time. As you can see, someone else here read the info provided in your own thread, and now knows more, as for you, your asking a questions but don't use the info already provided. At this rate, you're better off using Google for your basic answers.
#20
I'm not sure if you realize or not, but your wheels aren't hanging out in mid air, they are attached to the buggy with something called - yes you guessed it - suspension!
So you can forgive someone for sending you to a suspension article when you were talking about camber settings (wheel angling to some). Any time someone talks about suspension setup they will always talk about camber settings and adjustment.
Since no-one knew through telepathy that your car doesn't have adjustable upper camber links since you never detailed your car in the question, perhaps your reply shouldn't have been aimed at the person trying to help you out but rather at the choice of vehicle if you feel it's stupid to give you half the adjustment capability.
For now, maybe just return your settings to the way it came from the factory and be happy with your 'don't care' bashing life. If you ask questions and people try to help you then you have to just be grateful, not making excuses and dismissing what they have to offer.
RC cars have a level of complexity no matter what level you're driving at. Perhaps the KISS principle would work well here.
#21
Ease up guys, the dude asked what camber is and how much to run, not how does lowering my roll centre affect mid speed corner turn in...
As I said, slight negative camber = good. Positive camber = bad. You don't change camber by altering the position of the camber link. This changes the roll centre, not the camber. To change the camber, you adjust the length of this upper link. I'm not familiar with Himoto's but I would assume this link has threads on it or at least part of it which allows you to alter the length of the link and therefore, the camber.
#22
Trader Rating: 38 (100%+)
I'm not going to beat a dead horse, but what everyone else has stated is true and I do have to LMAO...
He cares, but doesn't want to know the details....Maybe we should just say, "It looks cool that way with your wheels "angled""....
The problem is there is a "science" behind why you want your wheels "angled". All we tried to do is "educate" someone and help them, help themself. But rather than COMPLETELY read an article and try and comprehend what it said, they just wanted to take the easy way out and basically say, "Tell me what to do, I don't want to know or understand what it does, I just want to know what to do"....
Which you can't unless you understand why you want that "angle"....
Now there is more than enough information in this thread to take a noob to journeyman, if one so chooses to do so.... "You can lead a horse......"
#23
As for the Himoto, I don't have one, but the ones I saw have wheel "angle" adjustments on the rear link just like the MBX5R or MP777. The front was also like a MBX5R or the MP777. Either turnbuckle or pivot ball adjustment. I have never seen a non adjustable camber 1/8 scale nitro buggy.
#24
i think you guys are talking about these:
http://carolinasrc.com/Webstore/Scri...?idproduct=556
i cant find a whole arm, but those are the things you spin and is that supposed to make more/less camber? thats not what i did. i just put one of my screws through a different hole thats behind the tire, and that angled the tire to a +camber.
#26
So i am assuming you went from the outer hole to the inner hole?? what you need to do then, is turn those threaded turnbuckles, so that the top of the wheel, will come back closer to the car, and be in the same position, as it was when the link was in the outer hole..
i just put the link into the inner hole so its like stock settings now. now i imagine if i turned that thredded thing closed it would make negative camber?
thanks, thats what i was looking for, ill try it later and see how everything goes.
#27
If you readjust camber for that new pivot point, you will have changed roll center, which will affect how the car goes around a corner. It's an adjustment used to finely tune how the car reacts. Since you're bashing with the car, it's not something you'll need to do and the adjustment is subtle enough that you might not even feel the difference.
#29
yeah thats what im talking about, thats not the same buggy as i have though. and my tire is vertical already (i put the screw back into the inner hole, taking my +camber away). i just gotta screw in those arms and hope it doesnt get stripped.
and skartisu: your 2/2 man, thanks a lot. im sure it will change the way the car handles, but like you said, i bash, and i probably wont even fell the difference. its just a himoto, and the difference will be insignificant.
pic of my himoto:
pic of my himoto:
