Old 11-25-2007, 10:18 PM   #1
SteveJa's Avatar
Trader Rating: 17 (100%+)
Default .21 head clearance how much ?
how much piston to head clearance should you have with a .21 ? and are most .21 the same ? Also this would be running with 30%.......
Also is the best way to measure this by putting a piece of solder through the glow plug hole, turn the motor over by hand... then measure that ??
if it does matter it would be for a n21bf and axe rossi mamba...
thanks
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 11-26-2007, 02:51 AM   #2
razzor's Avatar
For the Axe i know the sweet spot to be .50mm on 25% nitro so would say .55mm/.6mm would be where you want to be on 30%nitro.
Thats at the coast though.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 11-26-2007, 07:16 AM   #3
GHETTOTEACHER's Avatar
The normal head clearance for my .21 engines is 2.4 to 2.7 on piston to button. I usually shim my engines up to .90 to 1.0 for running 30%. I run RB and Novarossi motors.
The head clearance method using a piece of sodder is a great way to check head to piston clearance. Many people don't check this when they get new motors.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 11-26-2007, 08:18 PM   #4
SteveJa's Avatar
when you say 2.4 ~ 2.7 do you mean .024 ~ .027 inch.. because that would work to about .6 ~ .7 mm...
HATCHER RACING !!!!
Impulse R/C
Old 11-27-2007, 03:36 AM   #5
tex1's Avatar
Send a message via Yahoo to tex1
Wink
.024 to .027 would work fine for 30%. Hard to tell what he was saying.
I run Novas and RB motors and they all run good in this range. At the shop we set all of our customer's motors here and they work fine.
TEX
tex1 is offline   Reply With Quote
Old 11-27-2007, 07:47 AM   #6
My falt guys.. misplacing of the decimal point. You know what I was talking about!
Tool for head clearance. dj apolaro Onroad Nitro Engine Zone 18 08-21-2008 05:50 AM
Nitro Head clearance and Seal problem pracy Nitro Off-Road 1 06-29-2008 08:18 PM
o'donnell novarossi head, nova go tech .21 head,misc air filter thebert686 R/C Items: For Sale/Trade 20 01-08-2008 11:27 AM
Deck clearance/head shim size on Kyosho .28 TC_Tuner Onroad Nitro Engine Zone 1 09-22-2007 03:14 PM
Head clearance Maximo Onroad Nitro Engine Zone 25 10-29-2006 04:35 PM
