Old 11-25-2007, 09:47 AM   #1
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Default To tight of a pinch?
Hello all,
i have a OS 18 tm with a pull start. when i go to start it the pinch is so tight i cant even pull the string. when i put after run oil in it, it works for about 1 pull then it locks again. no its not flooded. why does it do this?
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 11-25-2007, 10:19 AM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
If its a new engine, heat the engine up with a hair dryer or heat gun. At 160F and up, it should be easier. If you pinched the engine, you may have pinched it too much.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 11-25-2007, 11:06 AM   #3
If you tried to resize it or had it resized the sleeve itself may be out of shape i.e. "egg shapped".
This will cause the piston to stick at TDC for sure.
If you resized it or had it resized, how was it done (hyd. press or "crimp tool")
It is called throttle control for a reason.
rc_freak is offline   Reply With Quote
Old 11-25-2007, 02:15 PM   #4
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
just heat up the block to as close to 200F as you can, and loosen the glow plug just a bit, and the engine should be much easier to start...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Pinch too TIGHT! rcfoolz Onroad Nitro Engine Zone 28 03-18-2008 04:41 AM
Pinch or no Pinch? JetMD Onroad Nitro Engine Zone 9 12-31-2007 08:29 AM
RE PINCH RACING MASON Nitro Off-Road 11 10-30-2007 07:00 AM
RB S7 NEEDS PINCH kwilke R/C Items: For Sale/Trade 23 05-11-2007 10:26 PM
Engine Pinch way to TIGHT!!! vw_shorty Monster Trucks 4 05-31-2005 03:13 PM
