Old 11-21-2007, 03:56 PM   #1
Ron_J's Avatar
Trader Rating: 18 (100%+)
Default Mugen MBX-5 build question?
Okay, so I'm stuck on the first step in the instructions. Pretty bad eh? It says to use "rubber glue" to put the brake pads on with. What is rubber glue, and where do you buy it?
Thanks, Ron
Ron_J is offline   Reply With Quote
Old 11-21-2007, 04:28 PM   #2
TonysScrews's Avatar
Don't use any glue.
Most guys ditch the rubber pads and steel discs and then use the TTR option brake discs, craddocks, or Avid RC Indos with just the metal calipers.
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 11-21-2007, 05:36 PM   #3
Originally Posted by TonysScrews View Post
Don't use any glue.
Best regards,
x2 the pads can become unglued when fuel , dirt and what ever else might get into contact with them. plus they work badly when nitro gets on them.
http://www.amainhobbies.com/product_...oducts_id/2546
http://www.amainhobbies.com/product_...ducts_id/14956
here are some examples of what to use. you wont need the pads glued on the calipers with these and they are more consistant and require less maintaining
mugenlife is offline   Reply With Quote
Old 11-21-2007, 05:38 PM   #4
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
Don't use any glue.
Best regards,
AVID brakes #1!!!!!!!!
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 11-21-2007, 11:20 PM   #5
Boz
Trader Rating: 23 (100%+)
Negative people. He only asked what to use. Ron_J only wants to build his new car.
I use a product called Kwik Grip. It works fine.
http://www.selleys.com.au/Selleys-Kw...t/default.aspx
Boz is offline   Reply With Quote
Old 11-21-2007, 11:35 PM   #6
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Zap is good thats what i used before i switched
http://www.amainhobbies.com/product_...oducts_id/9031
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 11-22-2007, 08:59 AM   #7
Originally Posted by Crim3Wav3 View Post
well, actually his question was "what is rubber glue"
answer: another name is rubber cement. It s a rubber based glue. You can pick it up at any hardware store....or Walmart.
yes it is rubber cement like the kind we used in elementary school...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 11-22-2007, 09:11 AM   #8
Crim3Wav3's Avatar
Crim3Wav3 is offline   Reply With Quote
Old 11-22-2007, 09:12 AM   #9
Crim3Wav3's Avatar
if you do use the original parts, make sure you sand the calipers and pads with a fine grit sandpaper in the areas in which you will be gluing....then clean them with isopropyl alcohol (or denatured alcohol)
Old 01-01-2008, 03:35 PM   #10
Ron_J's Avatar
If I opted for these "Avid RC Indos". Do I just eliminate the brake disk guides that fasten onto the bottom of the center diff brackets?
Thanks, Ron
Old 01-01-2008, 04:07 PM   #11
hansarvin's Avatar
Yes you do. Good choice on brakes, they should work well.
hansarvin is offline   Reply With Quote
New Build Mugen MTX3 w/ .12 os engine sprak74 R/C Items: For Sale/Trade 9 01-16-2008 10:25 AM
Mugen Question?? hiliter03 Nitro Off-Road 7 01-11-2008 04:26 PM
MTX-4 Build design question (brake binding) BIGTACO Nitro On-Road 2 10-04-2006 07:04 PM
Mugen X12 glowplug question snowboardgeek1 Onroad Nitro Engine Zone 28 08-04-2005 06:15 AM
Mugen Mst-1 Question Ducati998 Electric Off-Road 4 06-11-2003 06:44 PM
