Old 11-20-2007, 09:12 PM   #1
Trader Rating: 20 (100%+)
Default RTR 8ight Fuel choice?
Hey, guys. So I'm getting an rtr 8ight my first nitro and I need to choose a fuel. So the first question is, who's a good fuel manufacturer? The only thing directly available to me (through my LHS) is Losi Nitrotane, but I'm open to mailorder fuel. Anything significantly better than Nitrotane?
So for a moment let's say I go with Losi Nitrotane. there are 3 blends:
1. 20%
2. 20% Race
3. 30% Race
So I understand I might as well use the least expensive 20% for break in.. but for club racing should I go with the 20% or 30%?
So two questions. What brand, and what blend? This will be used with the stock TL427 engine.
Thanks, guys.
JeffEmbracedDC is offline   Reply With Quote
Old 11-20-2007, 09:41 PM   #2
Send a message via AIM to playboy Send a message via Skype™ to playboy
i got the losi 8 about 1 month ago and it is great with the acception of the servos. you will definetly need new sevos. i have the airtronics. i dont know what model they are but they were 120 dollors each.
the type of fuel that i use for my car is sidewinder racing fuel 20%. i used that for break in also.
now i am going to get the sidewinder racing fuel 30%.(after break in)
so far the car is awsome exept for the cvd pins and the screws on the bottom
of the car. take all of them out(one by one)and put lock tite on everything. screws tend to come lose on that car i dont know why
other than that you should be good
good luck
cya
playboy is offline   Reply With Quote
Old 11-20-2007, 09:45 PM   #3
Yeah, I have plans to upgrade the servos definitely. Right now I have a JRz650 that I'll be using for steering, but I'll probably want something more like the 9000t and get a faster metal geared high torque for the throttle.
I plan to go through the entire car before I run it. Loctite everything, check the engine, probably put a better breathing air filter on.. that kind of thing.
Yeah, I think a lot of guys around here use the sidewinder fuel too. Have you had experience with other fuels? I'm sure the Losi Nitrotane isn't bad and the fact that the shop stocks it 3 miles from my house is nice.. I'll see if I can get a quart of 20% for break in and some 30% for racing.
-Jeff
Old 11-20-2007, 09:47 PM   #4
Casper's Avatar
Trader Rating: 33 (100%+)
Byrons, Sidewinder and Nitrotane will all be good fuels for you. I would just break it in with the same fuel you will race with. 30% is what most people use for larger scales.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-20-2007, 09:48 PM   #5
Trader Rating: 37 (100%+)
Good question.
The closest LHS to me also stocks the same Nitrotane. I also have a new 8ight RTR to break-in and wondered if that fuel was any good.
Nexus is offline   Reply With Quote
Old 11-20-2007, 10:09 PM   #6
So, it's safe to break in with 30% fuel? It has enough lubrication?
I've got a temp gauge so I'll definitely be keeping an eye at that.
Another question - What is a good operating temp for this engine and nitro engines in general?
so..
1. Is it safe to break in with 30%? If I choose to do this, anything I should watch out for?
2. What's a good operating temp? what's too cold, what's too hot?
-Jeff
Old 11-20-2007, 10:18 PM   #7
Casper's Avatar
There should be plenty of lube in these. During break in the engine should be rich so it will have plenty of lube.
After break in the engine should be runing between 200-250.
Old 11-20-2007, 10:39 PM   #8
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i break in all my engines on 30%...IMHO i would chose byrons race 3000 30%...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 11-21-2007, 07:14 AM   #9
JeremyS's Avatar
Werks 30% is good stuff as well.
I break in my motors with what i will use to race....this way your not chasing your tune around. Temps at break in should be around 200-220. with lots of smoke and oil...to insure good lube. after break in you should be tuning for power ans smoke not temp. Temp is a referance to get you in the ballpark, but some motors like to run at 200 all day long with stupid power, others don't make good power until 260. as long as your getting good smoke and power you should be fine.
V-8 For life
Blue Oval Loyalist
If you ain't first....your last
JeremyS is offline   Reply With Quote
Old 11-21-2007, 08:25 AM   #10
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
good luck
cya
Why you use 20% for break inn and then switch to race fuel ?, you dont need to use that, just take the same fuel you will be using and break the engine inn with that fuel ... the engines are not animals, dont need to treat soft on the break inn period with not so powerful fuel lol!
cya !
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Battery choice for Losi 8ight truggy Vega Electric Off-Road 3 07-03-2008 03:23 AM
OFNA Ravager Fuel choice cfelix10 Electric Off-Road 5 03-02-2007 02:43 PM
Does Fuel Choice Matter in 1/8 Buggy? Banshee8530 Electric Off-Road 48 05-09-2006 04:57 PM
REX P5 Temp and fuel choice??? jeffrock Electric Off-Road 1 06-08-2004 01:28 PM
Fuel Of Choice?? VinDollar Nitro On-Road 18 03-06-2002 07:52 AM
