Old 11-18-2007, 07:46 PM   #1
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Default Good buggy/truggy tires for dry hard dirt
Hi,
What tires do you guys recommend for dry and hard dirt? I'm looking for something with good traction and long lasting.
Sometimes my local tracks run races dry. It kills me when a new set of tires are pretty much gone during 1 days racing.
Thanx
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 11-18-2007, 08:19 PM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
Originally Posted by teeforb View Post
Hi,
Thanx
for buggy try the Advantage Racing (DLD) ZZ's...ive had good luck with these tire in dry hard conditions...
for truggy i have been running crime fighter MTR's and GRP Grips with great luck...the CF's last a longer, but the grips stick to the surface better...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 11-18-2007, 08:23 PM   #3
Originally Posted by DOMIT View Post
I like Werks Lugs for hard packed tracks... they don't seem to wear as much as other brands with comparable traction. They're about equivilant to a Proline Bowtie with better wear.
WHAT the lugs are closer to a CF then a BT...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 11-18-2007, 08:23 PM   #4
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I like Werks Lugs for hard packed tracks... they don't seem to wear as much as other brands with comparable traction. They're about equivilant to a Proline Bowtie with better wear. Even the softer compound ones wear pretty long. I've run 4 heats and 2 mains on a set before and they're not worn much... still would run them in a main.
I also like Panther Komodo Dragons (I or II, but the originals have more foreward bite)
but... they wear faster.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 11-18-2007, 09:13 PM   #5
petevette's Avatar
Send a message via Yahoo to petevette
You may want to check out Team Cobra Racing's Tires. There rubber compound is different from most and longer lasting with great forward bite. You can search for Team Cobra on Ebay.
petevette is offline   Reply With Quote
Old 11-18-2007, 09:29 PM   #6
petevette's Avatar
teeforb, check out the Team Cobra Thread where TM America talks about the tires.
Old 11-19-2007, 10:55 AM   #7
If the it hard dry clay, almost to blue groove our Pythons fromTeam Cobra racing is perfect for you!
TM America is offline   Reply With Quote
Old 11-19-2007, 10:59 AM   #8
Moderator
badaml's Avatar
Trader Rating: 127 (100%+)
They only have buggy tires, nothing for truggy.
Cheap, Fast, Reliable - Pick 2.
Current:Traxxas Rally/Slash 4x4-Blade MQX
Past: Kyosho Raider, Traxxas GTP, Kyosho Optima, Jato 3.3, Tmaxx 2.5, Revo 2.5, Revo 3.3, TC4, MBX5t, Hyper 7, Emaxx, Vorza, Inferno VE, XXXT, Hyper Sprint, SC8e, Erevo, Rustler VXL, RC18b, Baja 5b, Parrot AR Drone, Mini ERevo VXL, HB D8Te, D8, Slash 2wd, Slash 4wd, HB Ve8,Blade 350QX, Alien Quad 450, DJI F450, DJI F550, Losi 8 3.0, DJI Phantom 3 Advanced, Traxxas Summit
badaml is offline   Reply With Quote
Old 11-19-2007, 11:26 AM   #9
DOMIT's Avatar
They are somwhere in between. Pretty dense pin count... a little rounder profile than the CF, a little flatter than the BT. Less sensitive to camber setting than the CF. The edges don't need to be clipped like most people (at least around here) do on the CF. Good all-around tire.
The BT and CF are both also good tires... they seem to wear somewhat faster than the Lugs, and that was part of the question.
ANY of those 3 are great tires. I'm not familiar with the other tires folks are suggesting on here.
Old 11-19-2007, 03:23 PM   #10
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
+1 on the Werks tires.
If the track is hard but really dusty, I would definitely run the W's in the R200 compound. The kewl thing about those tires is that you can run them when the track is hard and really dusty and as well when the track is damp and loamy.
Also the lugs are another great tire that can be use in multiple applications. If the track is just hard back and nothing else I would look at the Lugs in either the R200 or possibly the R300 compound, depending on the track.
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
Old 11-19-2007, 05:10 PM   #11
GHETTOTEACHER's Avatar
I got something for ya. The best for hard dry surfaces are Proline Holeshots and ya'll don't laugh.. Badlands. The Holeshots will burn up fast, but they do pretty good with blue groove style tracks. I tried the badlands because my Boe ties wern't hooking up. I was desperate. They worked pretty well! The funnything about this was that the next weekend, there were four more guys out there with Badlands.
Just a thought!
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 11-19-2007, 05:29 PM   #12
Davidka's Avatar
Trader Rating: 75 (100%+)
Panther Chameleon is a good tire for hard dry conditions too. Soft or Medium soft. If your dirt is hard packed and is abrasive enough to wear tires quickly than you want a more densly spaced knob pattern for better wear, the traction on this type of surface comes more from rubber to ground contact anyway. The Proline Knuckles were designed with this in mind too.
Old 11-19-2007, 05:53 PM   #13
What rims do you put the GRP's on? GRP rims?
revo_race is offline   Reply With Quote
Old 11-20-2007, 01:12 PM   #14
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
We have had a drought here all summer. Our track is amazingly dry, rutted and hard-packed. It is sort of like driving on sealed concrete with some dirt sprinkled here and there for effect.
Most people ran Komodo IIs with a few running Crimefighters.
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 11-20-2007, 01:30 PM   #15
With a track like that why aren't people running a tire like the Knuckles 2.0's?
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Used 1/8 Buggy and Truggy Tires jpalessi R/C Items: For Sale/Trade 5 09-06-2008 06:36 PM
1/8 Buggy & Truggy tires baruke1 R/C Items: For Sale/Trade 9 06-09-2008 10:30 PM
1/8 buggy and truggy tires mach51 R/C Items: For Sale/Trade 3 04-21-2008 08:14 PM
Good pull start engine for buggy/truggy Car Breaker Electric Off-Road 2 02-04-2006 08:57 PM
Losi Dirt Spec Buggy Tires Rears and 4wd fronts Cain R/C Items: Wanted to Buy 0 02-04-2005 01:02 PM
