Old 11-18-2007, 08:45 AM   #1
crazyjr's Avatar
Default Clutch bearings for 8T
I just wore out the second set of clutch bearing, for the clutch of my Losi 8T. I am debating wether to go with good ceramic, or cheap Losi bearings. I would like opinions from those who race Losi's and their experiences, and links to what you use.
thanks for any info you have to spare
crazyjr is offline   Reply With Quote
Old 11-18-2007, 09:10 AM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
doent waste your money on the hi priced ceramic bearings...clutch bearing just wear out fast and there is nothing that can be done about it...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 11-18-2007, 09:18 AM   #3
crazyjr's Avatar
Thank you. I figured as much, but thought i'd ask before getting a 5.00 set of bearings. Does anyone know the exact size of the bearings? I think avid rc bearings would be perfect
Old 11-18-2007, 09:21 AM   #4
http://www.amainhobbies.com/product_...oducts_id/8947
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 11-18-2007, 11:24 AM   #5
houston's Avatar
Trader Rating: 91 (100%+)
Talking
avid revolutions are the best bang for your buck bearings on the market!!!! if you want more life out of them try this method , using your heat gun , lay the bearings on your pit towel rubber side down , heat up the bearing for about 15-20 seconds to melt the lithium grease out and while it is still hot drop 2 or 3 drops of a synthetic gear oil !!! this is the best method i have found to make clutch bell bearings last after 7 years of nitro racing , i have been doing it for about 2 years and cut the cost of clutch bell bearings by 75% !!!! seriously!! i re-oil the bearings after 30 -45 minutes of run time on the bearings and have used 1 set of bearings for 6 hours of run time with a three shoe aluminum kyosho clutch with 1.0 springs !!! unheard of . I ran the losi buggy for about 2 gallons and found this method to work great with the same kind of bearings ( inboard bearing size is 5mmx13mm ) and the same treatment as above
hope this helps,
Monty
and by the way , the losi buggy is no where near a kyosho buggy in performance !!!! the losi is all tricked out and sitting on my pit shelf !!!! wanna buy it ???
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 11-18-2007, 05:46 PM   #6
crazyjr's Avatar
Thank you much for the info, i assume the outer bearing is a standard 5X10mm.
Houston, I appreciate the offer on the buggy, but i got a lightning 2pro that I'm satisfied with, for the time being till i get to drive one and see if i like it
Old 11-18-2007, 06:13 PM   #7
Radron's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to Radron
Houston is right, I've been runnning Avid bearings thru-out all my cars with great success!
Radron is offline   Reply With Quote
Old 11-27-2007, 07:58 PM   #8
crazyjr's Avatar
Thanks guys for the info, I just ordered a ten pack of each from AVID
Mini mgt clutch bearings shipwama Monster Trucks 1 07-24-2008 10:53 PM
Stainless 5 x 10 clutch bearings AEracer40 R/C Items: For Sale/Trade 6 05-11-2008 06:24 PM
problems with clutch bearings on 8t rhymster Nitro Off-Road 13 09-10-2007 04:25 PM
5X10X4 Clutch bearings SAM5 Australia For Sale/Trade 1 08-06-2006 04:44 AM
Clutch Bell Bearings...help binaryterror Electric Off-Road 8 08-02-2006 11:04 PM
