Old 11-17-2007, 08:51 PM   #1
Default clutch shoes/spring installation how to?
whats the easiest way to get those damn clutch shoes/springs onto the flywheel, i just cant figure it out.
ps: i tried searching "clutch" and "clutch spring" and i couldnt find anything. i have a feeling im doing it wrong?
what happened? is offline   Reply With Quote
Old 11-17-2007, 09:31 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
what manufacturers clutch is it ?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 11-17-2007, 09:37 PM   #3
UN4RACING's Avatar
Trader Rating: 22 (100%+)
This is a clutch shoe/spring tool. It collapses the spring. I prefer to just use a screwdriver to put them on. This can help to pull them off.
http://www.sportwerksrc.com/Search/D...ch=Clutch+tool
UN4RACING is offline   Reply With Quote
Old 11-17-2007, 09:59 PM   #4
it said there was an error with the site or something..
the manufacturer is OFNA racing flywheel, clutch, shoes and springs are all OFNA. engine is lrp .28 zspec.
Old 11-18-2007, 12:01 AM   #5
houston's Avatar
the ofna / jammin stuff is pretty easy to install . you probably havent ever put a 3 shoe clutch system together i am willing to bet ?? looking at the flywheel installed on the crank , the engine will rotate counter clock wise , the clutch shoes hang off of the posts so that they trail in rotation make sure you use the spacer shims that go under the shoe , then install the shoes with the spring in the shoe over the post , make sure the part of the spring that sticks out of the shoe to the inside is on the side of the crank that would pull the shoe into center and closed position and create tension when you stick your tuning screwdriver between the crank and the mentioned tail of the spring . spread it out a little while pushing down on the shoe , should slide right on if you are using the 1.1 gauge springs then you may have to use a 3 shoe clutch tool as they are very high tension and you will more than likely end up stabbing your palm , and it hurts
hope this helps,
monty
Old 11-18-2007, 06:10 AM   #6
UN4RACING's Avatar
Search clutch tool.
Old 11-18-2007, 10:36 AM   #7
Originally Posted by houston View Post
the ofna / jammin stuff is pretty easy to install . you probably havent ever put a 3 shoe clutch system together i am willing to bet ?? looking at the flywheel installed on the crank , the engine will rotate counter clock wise , the clutch shoes hang off of the posts so that they trail in rotation make sure you use the spacer shims that go under the shoe , then install the shoes with the spring in the shoe over the post , make sure the part of the spring that sticks out of the shoe to the inside is on the side of the crank that would pull the shoe into center and closed position when you stick your tuning screwdriver between the crank and the mentioned tail of the spring . spread it out a little while pushing down on the shoe , should slide right on if you are using the 1.1 gauge springs then you may have to use a 3 shoe clutch tool as they are very high tension and you will more than likely end up stabbing your palm , and it hurts
hope this helps,
monty
hmmm, i can get them in the proper position and that, but i just cant get the springs to fold back like theyre supposed to, around the flywheel nut. im not sure what kind of springs they are, they are gold. and what did you say about the washers? i didnt put those in... should i have? and where do i put em?
and yes, ive stabbed my palms many times, its not fun at all.
WTB: Revo clutch shoes with spring JSY R/C Items: Wanted to Buy 2 05-14-2007 08:33 PM
Installing Clutch Shoes/spring Kwilli Electric Off-Road 6 08-12-2005 12:35 PM
Orion 19T Element V2 Brush/ Spring Installation hollisst Rookie Zone 1 07-05-2005 12:17 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
duratrax clutch shoes&spring n evad st savage13579 R/C Items: For Sale/Trade 0 11-02-2003 11:39 AM
