Old 11-17-2007, 12:59 PM   #1
Trader Rating: 37 (100%+)
Default Offroad Nitro Engine Tuning Tips.
I know in the onroad section there is an engine forum but hate jumping back and forth.
Was just looking for good tips and/or links to learning about nitro engine tuning.
Example questions I have.
- What's the difference between running 20 and 30% fuel?
- turning this or that needle does what?
- Why do I have to shim the glow plug for different fuel?
nitro for noobs sorry
Nexus is offline   Reply With Quote
Old 11-17-2007, 01:19 PM   #2
tdeal823's Avatar
Trader Rating: 30 (100%+)
Do a few searches and you will find a ton of info on this subject.
But for nitro content you are not shimming the plug you are shimming the gap between the top of the piston and the bottom of the head or head button.
most all .21's come setup for 30%.
good luck if you have a specific problem state that and we all can help
tdeal823 is offline   Reply With Quote
Old 11-17-2007, 01:29 PM   #3
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
lots of good info here Engine Tuning 101 (General Tuning)
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-18-2007, 09:47 AM   #4
Thanks...great link.
I'll be initially learning on the 8ight RTR Mach427 engine.
Old 11-19-2007, 11:59 AM   #5
pitpop's Avatar
Here is my top secret tuning tip:
"Lean the bitch out, if it aint runnin' on, yur good."
pitpop is offline   Reply With Quote
Old 11-19-2007, 06:57 PM   #6
houston's Avatar
Trader Rating: 91 (100%+)
Talking
you forgot to tell em they need to run sirio engines and now sidewinder fuel paul ,
if you dont get engines for free then tune wisely my son and remember ,"fuel makes power , not air !"
later ,
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-02-2007, 05:42 AM   #7
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Hi guys, anyone of you tune the engine by hearing the sound or follow the engine temp? My engine when I run at straight it run great but when I temp it it already at ~120C. If I rich it and run ~100-110C it run abit sluggish. So which method is good from your opinion. Please advise and thanks.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 12-02-2007, 07:52 AM   #8
jgtruggy's Avatar
I have this engine in my 8T and it is a great engine. To get all of what the engine can put out, buy a starter box and back plate. Oh, you'll also need a different engine mount. Change the grease in the diffs to sillicone. Check out the set up sheet on the 8ight for the weight for each diff.
Losi SCTE
Tekin RX8/Tekin Pro-4 4000kv
Topgearhobbies.com
jgtruggy is offline   Reply With Quote
Old 12-02-2007, 08:09 PM   #9
houston's Avatar
wherever the engine makes the most power is ok !!! with a stock cooling head 270 is kinda reachin the limits but i have seen engines that wont make the most power till they hit 290 !!! if it starts to lean bog richen it up , if it is just boggy and smokin , lean er out !!!! when power starts to drop off while tuning back off and call it good !!! remember fuel makes power , not air !!!
later , monty
nitro .21 engine tuning help? downunder23 Rookie Zone 14 05-16-2013 08:52 PM
Nitro Engine Tuning 101 x 4 mad-dog Onroad Nitro Engine Zone 0 08-27-2007 07:48 AM
Engine tuning tips zardoz Nitro Off-Road 6 07-13-2007 07:28 PM
Nitro engine tuning atr4tigers Nitro On-Road 2 06-24-2006 09:07 PM
Engine tuning tips AMGRacer Nitro On-Road 10 11-14-2001 11:29 PM
