Old 11-17-2007, 05:32 AM   #1
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default Wheel balancing
Hi all, anyone here hear about balance out wheel? I know some is balancing their turggy wheel but not sure do buggy wheel need to be balance. If need then which is best tool to buy. Please advise and thanks.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 11-17-2007, 06:12 AM   #2
TeeKuang's Avatar
Usually, I just ask Mr. Google, with the magic of Mr. Google, I found this http://www.redrc.net/2007/10/ultimat...tire-balancer/
Best Regards, Tee Kuang
Rovan 290S
Killer Bee Kill switch | Outerwears | hydraulic brake | Ace DS-1015 |ADA Rear billet hub bearing carrier | Hostile Nightmare MX | RCMOD Closed clutch |
Gasoline POWER : Malaysia Large scale hobby
TeeKuang is offline   Reply With Quote
Old 11-17-2007, 01:09 PM   #3
jrwoodchuck's Avatar
I use this one.
http://www3.towerhobbies.com/cgi-bin...&I=LXD712&P=SM
I use a 17mm hub and wheel nut as adapter for the balancer. It's not as nice as the other one, but it works great.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 11-17-2007, 06:42 PM   #4
MadRacer's Avatar
Trader Rating: 33 (100%+)
Doesnt matter what you run all tyres need balancing.
The bigger the more critical it is. I balance all my tyres no matter what class or vehical. I use a Dubro prop balancer and use blu tact as weight.
MadRacer is offline   Reply With Quote
Old 11-17-2007, 08:35 PM   #5
dubum's Avatar
Trader Rating: 85 (98%+)
http://www.ballisticbatteries.com/St...757&InfoID=200
This is the one I use and it does not show it , but all sizes are done using only one step arbor. It is a really strong unit with a heavy base so it will not tip. I no longer use the putty as dirt seems to stick to it extremely well, so I now use lead tape with wonderful results. It really does make a difference!
dubum is offline   Reply With Quote
Old 11-17-2007, 08:37 PM   #6
rregl0612's Avatar
Originally Posted by jrwoodchuck View Post
I use this one.
I agree.. not sure on the price of the ultimate racing one.. but the prop balancer can be found at most hobby shops..
I took it one step further....... Order a 8mm drill blank from Mcmaster - carr
or any machine supply place.. then drill and tap a 17mm hub .. run a grub screw ( set screw ) of choice.. and wallaw.. a super solid way to mount and true your 1/8 buggy and truggy tires...
rregl0612 is offline   Reply With Quote
Old 11-18-2007, 12:10 AM   #7
MadRacer's Avatar
Is that with the prop balancer???
Old 11-18-2007, 01:41 AM   #8
rregl0612's Avatar
yes.. with the prop balancer....
www.mcmaster.com part number 2900A358 I believe is the one I used.. there are others if you search.. definately worth the 6$ investment made finding centers a snap!! no guess work..
Old 11-18-2007, 08:15 PM   #9
MadRacer's Avatar
Thanks...
Old 11-19-2007, 10:44 AM   #10
Ultimate Racing's Tire balancer, the one mad for balancing tires, will be in stores in the next couple of weeks. The first shipment into the USA will on it's way the middle of this week. I can tell you rightaway that A Main hobbies will hve the balancer and UR products as soon as they hit the states.
TM America is offline   Reply With Quote
Old 11-19-2007, 11:16 AM   #11
If I see a tire on my buggy bouncing like crazy on my starter box as I rev the engine then I balance it. If not, I don't.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 11-19-2007, 03:00 PM   #12
rregl0612's Avatar
So welcome... : )..
I balance everything..... will say the bigger the tire the larger the difference in driving feel... However.. I have noticed a increase in bearing life under normal conditions since I started this... I used to get sloppy wheel bearings ( in and out play. bearing still spun freely.) about every 2 months. in 1/8.. and truggy... now Im at 3 months and bearings are still tight.. and thats even with a big 3 day weekend race thrown in there!!
I used to balance only what was visible... the largest difference in your driving that you will notice will be adjustments made in the air seem like you are more in control... not as abrupt...
Old 11-19-2007, 06:49 PM   #13
Trader Rating: 26 (100%+)
I found after I balanced my truggy wheels it didn't seem to get tossed around in the rough stuff as much, along with the other stuff mentioned,
bobf24 is offline   Reply With Quote
Old 11-19-2007, 07:00 PM   #14
rltanner's Avatar
IM trying it out let you know
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 11-19-2007, 07:03 PM   #15
Using molded foams seems to greatly decrease the need to balance.
Bruce Edwards
Thanks to:
Wheel balancing pole_position Singapore R/C Racers 4 03-19-2007 08:27 PM
KO Propo EX-10 Helios w/ Drop wheel extension and hex wheel adaptor Justin Zorc R/C Items: For Sale/Trade 6 02-28-2007 09:32 PM
wheel balancing pug 205 gti Electric On-Road 10 02-12-2007 05:16 PM
Vintage RARE Kyosho Progess 4WS (4 Wheel Wheel Steering) assoc_driver Australia For Sale/Trade 0 01-16-2006 07:34 AM
·New TakeOff dish wheel VS Cross spoke wheel· ZER01 Electric On-Road 29 10-04-2003 04:14 PM
