Old 11-13-2007, 10:27 PM   #1
Default Pictures of modified V-spec sleeves
Hi, can someone please post pictures of modified sleeves for the V-Spec (eb mods, JP, OS Speed etc).
Would be interesting to see the difference.
Frode
Tigergutt is offline   Reply With Quote
Old 11-14-2007, 08:16 AM   #2
rltanner's Avatar
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 11-14-2007, 09:57 AM   #3
Trader Rating: 38 (100%+)
LOL! would be interesting to see or are you thinking that you'd grab a dremel and make an attempt of your own, basically duplicate their work?
The sleeve is only only a small part of a modified engine. The piston, crank, button head, and even the crank case itself may have been worked.
There are many great articles on 2-stroke engine porting. Read up. You'll see/learn that engine porting governed by many factors such as rod length, port height within the case itself...
Just looking at a piston sleeve and "unlocking" speed secrets just isn't going to happen...
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 11-14-2007, 04:12 PM   #4
22Racer's Avatar
Trader Rating: 67 (100%+)
I looked at modded V-spec that was ran by a pretty good sponsored racer. They modded the crank and sleeve but didn't even touch the sharp edge on the exhaust where it meets the pipe or touch anything in the case (most italian engines have a nice break or radius on the exhaust) To me the sleeve on a v-spec is pretty decent from the factory, I think you can gain alot with the work on the case.
Rex
22Racer is offline   Reply With Quote
Old 11-14-2007, 04:55 PM   #5
tmperformance1's Avatar
Send a message via Yahoo to tmperformance1
anybody who would post a pic of a modded sleeve or crank is doing the modifier a big disrespect. these guys spend countless hours fine tuning there cuts and not to mention r&d time an money. good engine modifiers who know what to do to each specific engine and application have spent hundreds of hours and thousands of dollars on r&d not to mention equipment used to make each cut the same. cnc machines for instance aint cheap. if you want to know the difference talk the modifier himself he will explain to you what u need to know. when choosing a modifier look at his resume see what races his motors have won. www.murnanmodifiedmotors.com check him out good guy and the motors scream.
Mugen Seiki,Sidewinder Fuels,Airtronics,O.S.Engines,AKA Products,Ascendency Racing clutches,Fastlane Graphix,TKO,IDRC,M2C RACING
tmperformance1 is offline   Reply With Quote
Old 11-14-2007, 06:12 PM   #6
jpz_67's Avatar
Trader Rating: 56 (100%+)
Yeah, true that. My good friend here where I run modifies a lot of peoples motors including my own and as a courtesy I always keep the engines no matter what. Even when they are wore out I hang on to them so they are not getting circulated for others to dissect.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 11-14-2007, 06:22 PM   #7
Maximo's Avatar
Well its not a V-Spec... But here is the sleeve of a Picco P7R EVO2 i have modified... This whole sleeve was done 100% by hand files, only using a dremel for final smoothing...
Maximo is offline   Reply With Quote
Old 11-14-2007, 06:41 PM   #8
22Racer's Avatar
I haven't seen any modded motors that looked like they were done on a cnc. I have alway's been curios why the Picco motors transfer ports are angled the wrong way? (I'm assuming cost, because everything is done from one angle)
Maxximo, nice looking sleeve, usually the cut on the side ports are both on the exhaust side.
Rex
Old 11-14-2007, 10:32 PM   #9
Maximo's Avatar
I dont seee how the Picco transfers are cut wrong... these motors make massive power on the dyno... If Picco is doing something different its obviously working....
Old 11-15-2007, 02:11 PM   #10
22Racer's Avatar
The air traveling through the tranfer port flows the opposite way (from inside out) On Novarossi's and the Axe Rossi I've worked on the transfer ports angle upward to help flow. The Picco's are the same angle as the ports, it must not be a big deal because I know picco's have good power.
Rex
Old 11-15-2007, 02:56 PM   #11
Maximo's Avatar
Rex
Ahh your refering the to the bypass ports, not the transfer ports.... the 2 small ports on the lower portion of the sleeve correct ??????
the the Picco transfer ports are no different then any other mills..
Old 11-15-2007, 04:15 PM   #12
mremtr's Avatar
AH BUNK ! if you post pics of these moddified engine parts nobody is going to send out the spy police to take you down ! If you think that the big modders' out there don't know what the other is doing ,your nuts!! They don't care they believe what they do is good for their app. I have talked with a bunch of them and they know! And they do their own style of modding and stand by it.
mremtr is offline   Reply With Quote
Pictures of my modified monster. MPpower Monster Trucks 14 11-23-2010 10:20 PM
JP MODIFIED OS .21 V SPEC eddie10 R/C Items: For Sale/Trade 3 06-29-2007 07:58 PM
JP Modified O.S. V-spec 8ightScale/CJP Onroad Nitro Engine Zone 38 04-02-2007 01:25 AM
SK Modified Spec Racer excalibur oval tmaxxking R/C Items: For Sale/Trade 29 05-03-2006 09:58 PM
Trinity Chameleon 19 Turn Spec Modified Joel Lagace Electric On-Road 14 09-26-2002 05:03 PM
