Old 11-13-2007, 07:28 AM   #1
Default Question about thread lock
I have a screw in the drive-train of my truck that works itself out every time I run the truck. When the screw comes out it disables the 4WD.
Is thread lock the only way to get the screw to stay in? If so, is the thread lock permanent? After using thread lock will I be able to get the screw out if I need to perform maintenance on the truck?
Imperator is offline   Reply With Quote
Old 11-13-2007, 07:39 AM   #2
Use the Blue Loctite. It can be removed. If it's a little tough to remove use some heat from a heat gun or soldering iron.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 11-13-2007, 07:52 AM   #3
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
Both the blue and red can be removed though the blue is easier to get off.
The trick in both cases is not to over-apply it. I will generally put a drop on the threads and then run my finger around it so that it gets into the threads but isn't globbed up on the screw.
Put less on to begin with. If it comes out, try again with a little more.
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 11-13-2007, 07:55 AM   #4
TeeKuang's Avatar
You must clean the screw throughly, make sure it's free from oil.
TeeKuang is offline   Reply With Quote
Old 11-13-2007, 08:01 AM   #5
You have to give it time to dry also. Don't just put it together with some loctite and go run it. Give it a little time. Is it in a place where you can get some heat shrink around it? That helps keep pins in also.
jbrow1 is offline   Reply With Quote
Old 11-13-2007, 12:44 PM   #6
Suspended
Send a message via AIM to Nay0k
I mostly use the Blue loctite for screws going into non plastic parts, e.g. putting an engine in place, as said the screw should be cleaned of any residue left behind before you put any loctite and attempt to screw it in. There's a good chance it will still come out easily when you need to perform maintenance, and if screwed in just tight enough it shouldn't present on track problems either, it doesn't need to be very tight (by hand) as that's the loctite's job essentially.
Nay0k is offline   Reply With Quote
Please lock thread juise R/C Tech Site Forum 0 07-31-2008 04:17 PM
thread lock RaceANissan616 Rookie Zone 14 07-26-2006 05:48 PM
Thread lock blues joeling Rookie Zone 8 08-29-2005 11:31 AM
Thread Lock rcburner Nitro On-Road 6 08-19-2005 11:20 PM
thread lock was ist los? Electric On-Road 2 09-08-2002 07:24 PM
