Old 11-12-2007, 03:16 PM   #1
Default Cleaning Questions?
Hello,
I am new to r/c and have some questions I was hoping you could help me with. I have a MBX5T Prospec and I would like to clean the electronics and motor. I have removed the electronics as a whole(the whole tray w/ battery/receiver housing and servos) and I am wondering the best way to clean this as a whole. I have some of the nitro-blast cleaner, should I spray that stuff clean? Should I use a damp rag to remove the dirt? Any suggestions would be appreciated.
Next, the motor.....I have an RB TM 928, I have removed it from the chassis and would also like to clean this. Simply just to get the dirt off. Again, should I spray the nitro-blast stuff to clean this? Should I use a damp rag to remove the dirt? Any suggestions would be appreciated.
Thank you!
Mondo is offline   Reply With Quote
Old 11-12-2007, 03:20 PM   #2
Chevron89's Avatar
On your electronics use a mixture of half simple green and half denatured alcohol it will not hurt it! Than scrub it with a soft tooth brush and blow them off with an air compressor. On your engine just spray the engine with the nitro blast scrub it down with a tooth brush and blow it off with an air compressor as above.
Chevron89 is offline   Reply With Quote
Old 11-12-2007, 03:21 PM   #3
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
I use a paintbrush to brush off as much dirt as I can first.
I would NOT use nitro cleaner on electronics themselves. Wipe them down with a rag damp with Simple Green or rubbing alcohol.
As for the engine - plug the carb and spray it with nitro cleaner, scrub with brush, spray again. Rinse. Lather. Repeat.
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 11-12-2007, 03:22 PM   #4
SMcpot's Avatar
Trader Rating: 22 (100%+)
I try to avoid using any liquid around my electronics....usually, compressed air or a soft bristle brush will remove most anything. And, assuming you've covered the openings on the engine (carb, exhaust) to prevent any loose dirt from being flushed inside, nitro blast should work fine (I'm partial to Simple Green).
SMcpot is offline   Reply With Quote
Old 11-12-2007, 03:26 PM   #5
Simple Green tastes much better than other cleaners when it splashes into your mouth.
Old 11-12-2007, 03:57 PM   #6
Thanks for the input.....on plugging the carb and exhaust, question. Can I use fuel tubing then, seal off the fuel tubing with a body clip or are there actual parts that can be used/purchased to plug these areas.
Thank you for all the help!
Old 11-12-2007, 04:01 PM   #7
I use automotive rubber vacuum caps. You can get a small assortment pack from any auto parts store.
SOMETHING LIKE THIS
Note that I had them already. I didn't buy them specifically for this purpose.
Old 11-12-2007, 05:05 PM   #8
SMcpot's Avatar
....or saran wrap and rubber bands.
Old 11-12-2007, 05:23 PM   #9
That is to much work.
Old 11-12-2007, 05:30 PM   #10
SMcpot's Avatar
But it's cheap and convenient
Old 11-12-2007, 05:32 PM   #11
salteen's Avatar
Trader Rating: 90 (98%+)
where do you guys buy denatured alcohol?
salteen is offline   Reply With Quote
Old 11-12-2007, 06:01 PM   #12
Any pharmacy, supermarket or home improvement store.
Denaturated alcohol = rubbing alcohol.
Old 11-12-2007, 06:28 PM   #13
rltanner's Avatar
Ace is the place for me
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 11-12-2007, 07:44 PM   #14
zardoz's Avatar
Send a message via ICQ to zardoz Send a message via AIM to zardoz Send a message via MSN to zardoz Send a message via Yahoo to zardoz
Denatured alcohol is different from rubbing alcohol. I'm not 100% sure about the differences though.
zardoz is offline   Reply With Quote
Old 11-12-2007, 07:47 PM   #15
zardoz's Avatar
I usually brush everything down with a big paintbrush. The details I use a really small wire brush. I then wipe everything down with oddly enough baby wipes (sorry, i got 3 little ones ) This seems to work really well and ensures that nothing gets where it doesn't belong.
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-10-2008 11:03 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 01:19 PM
Nitro cleaning questions sfxpete Rookie Zone 6 11-12-2002 09:47 PM
