Old 11-12-2007, 12:52 AM   #1
rcstunt101's Avatar
Trader Rating: 16 (100%+)
Default New to nitro - engine and servos.
I have a lossi 8ight used race ready roller and am getting ready to choose engine etc. Im thinking of getting the Axe rossi mamba but there seems to be 2 versions - turbo and standard. Which will be better for the losi 8ight. Im also going to get 2 ace digital servos for around 100 each for steering and throttle. Will the Axe 2050 EFRA Polished Pipe Only be good for the mamba aswell? Cheers in advance
Associated TC5R
Associated B4
Yokomo B-max4
LRP, Intellect, Futaba
rcstunt101 is offline   Reply With Quote
Old 11-12-2007, 04:09 AM   #2
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
i would get the turbo version of the Axe. it gets more power and better gas milage.
the ace 1015, 1013 servos put out very good power and speed. they would be my choices.
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 11-12-2007, 06:51 AM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
The turbo button makes more power but on the mid to top end. Its not needed and you can get it with either one and change the head button later. I prefer the standard head. The Thunder Tiger pipes are great also. Use the TT 2035 for bottom to mid power, or 2039 for mid to top power. Ace servos I hve no clue on. I've only used the Futaba S9351 & S9350 servos, which are enough for me.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 11-12-2007, 12:44 PM   #4
Registered User
Hey rcstunt, get yourself a JP3 pipe, Braz borrowed mine and I dont think i am getting it back.... go a hard anodized versions they are easier to clean!!!
Loop&Roll is offline   Reply With Quote
Old 11-12-2007, 01:10 PM   #5
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Unless I am mistaken, they recommend replacing the con rod after break in, due to the amount of pinch that motor has. Keep that in mind. That engine is supposed to be just plain EVIL FAST.
I run the HS-5945MG (Hitec) on steering, seems to be adequate, and it was about $55. Would probably be a better throttle servo though. For about $120, the king of steering servos is the Hitec 5995-TG at 333 in/oz at 4.7v, 417 in/oz at 6v, and speeds of .16/.13 respectively... that's my next upgrade, and I'll move the 5945 to throttle.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 11-12-2007, 01:17 PM   #6
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
ace and futaba have the best servos out right now. so making the choice for the ace servos is a good one.
micrors4guy is offline   Reply With Quote
Old 11-12-2007, 03:35 PM   #7
sport10's Avatar
The JP3 is one of the recommend pipes for the Mamba. This motor has a good powerband but runs out of steam on top if you have a large track. The cobra is better for large tracks where top end is crucial. The idle on the Mamba is the best I have seen. Just make sure to install the extra shim if you are going to run 30 percent fuel. This will make the engine easier to tune too.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 11-12-2007, 04:05 PM   #8
Maximo's Avatar
if you are new to Nitro..the AXE Mamba may be a little difficult to break in for you.... These motors are very tight and will be very picky to tune and run for about the first 1.5 gallons.... to a person new to the hobby this could prove very frustrating, and could lead to you ruining the engine.... A motor like a LSOI Mach 427 will make as much power as the Mamba, but be much much easier to break in and tune.... You would be wise to learn the basics on a throw away mill like a Mach 427 before you buy a higher end motor like a Mamba....... The Mach 427's are about as user freindly as a nitro motor can get, and they make amazing power and RPM for its class of engine....... Once you have burnt a few gallons with the mach then consider buying a good .21........ As beleive it or not, but you being new to nitro I guarantee a mach 427 is going to offer you alot more performance then that mamba will.... That mamba will be picky to break in and tune, and really wont wake up for about 1.5 gallons ( Axe Rossi have tight motors) whereas the Mach will be screaming like a Banshee in about 10 tanks..........
Without question though, once you learn the ropes on a Mach, you will be able to move up to the high performance .21's quite easily.... But for a newbie some of these tight italian .21's may be quite overwhelming.... They are great motors though, but they need more skill to woek with.....
Maximo is offline   Reply With Quote
Old 11-12-2007, 04:23 PM   #9
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Agreed. Rody from RB Concepts also recommends the same, which I have done with both my RB engines. He also recommends replacing the conrod every 1.25 gallons to play it VERY safe. I took this from here.
Personally I replace the conrod after break-in and about half way through what I feel the engine life is, or if the conrod falls off the crankpin with a soft tap, which means there is just a hair too much play.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 11-12-2007, 04:27 PM   #10
get something smooth and learn to drive flawless THEN get faster engines. 3/4 of the guys with ultra fast engines cant even use what they have correctly and get beat soundly by those who drive smooth. Go tech 3 port, Nova BF21 or Dynamite Platinum is all that is needed. OWN the infield you will win the race.
mugenlife is offline   Reply With Quote
Old 11-12-2007, 04:50 PM   #11
rcstunt101's Avatar
what about the mamba sport? What is it like to tune and running wise?
Associated TC5R
Associated B4
Yokomo B-max4
Old 11-12-2007, 05:36 PM   #12
ezveedub's Avatar
My Axe Rossi Mamba was easy to tune. I run it with a TT 2035 header & pipe. Stable idle and quick snappy bottom end and easy 190-235F temps depending on you needle settings and ambient temperature. Plus if you need more power, drop in the X1 EVO package. Cheapest full upgrade I have seen out right now. You can run the Novarossi, RB or Axe Rossi glowplugs. They use the same heat range and reach.
Old 11-12-2007, 06:33 PM   #13
rltanner's Avatar
I got a Losi 427 from a freind and yes the motor makes great power but my gas mileage isnt the greatest but still messing with it
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 11-12-2007, 06:54 PM   #14
Maximo's Avatar
that just it.. A Mach 427 makes great power, but it is a pig on fuel... but its also very forgiving and easy to tune...
Old 11-12-2007, 06:54 PM   #15
RACING MASON's Avatar
Send a message via ICQ to RACING MASON
R.C. SYNDICATE RACING
Lake Havasu City AZ
Slash
Revo
CEN Matrix TR FRE
RACING MASON is offline   Reply With Quote
HPI Nitro R40 Hara Edition Kit + ENGINE + PIPE + SERVOS + BATTERY GymBeam Australia For Sale/Trade 11 04-03-2007 10:38 PM
MAYHEM PRO, RB engine, WITH SERVOS biker R/C Items: For Sale/Trade 7 06-05-2006 04:20 PM
WTB: Engine, servos, PT, etc.... Packfan R/C Items: Wanted to Buy 5 09-05-2005 05:58 AM
FT RC10GT w/Engine+Servos JonB R/C Items: For Sale/Trade 1 10-08-2002 04:57 PM
FOR SALE:Nitro 4tec, Hopped Nitro Rustler, Parts lot, Picco .12 engine, plus more!!!! feel my impact R/C Items: For Sale/Trade 0 08-05-2002 09:41 PM
