Old 11-09-2007, 07:35 PM   #1
Trader Rating: 73 (100%+)
Default Brand new motor binding....any sugestions?
I have a .12 Picco red dot that spun freely at bottom dead center until I tightend up the flywheel nut. Its a bump start engine. It feels like the flywheel pulls the crank agaist the main bearing. As soon as I loosen the nut and pop off the flywheel is spins freely again. Could it be defective? I have never had an engine bind like this when you tighten up the flywheel.
Any sugestions?
losifiend is offline   Reply With Quote
Old 11-09-2007, 07:38 PM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
maybe try shimming the collet...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 11-10-2007, 09:01 AM   #3
JeremyS's Avatar
hi losi,
as jason said, put a shim or two on the crank before the collet and flywheel.
you want just a tinytinytiny bit of slop when you move the crank lateraly. i mean you could debate with someone if there is any movement....thats how little of slop you want...but you do want that little bit.
hope this helps.
V-8 For life
Blue Oval Loyalist
If you ain't first....your last
JeremyS is offline   Reply With Quote
Old 11-10-2007, 10:42 PM   #4
gubbs3's Avatar
I agree, shim the flywheel slightly. Most likely the flywheel is binding against the crankcase. I have personally never seen a crank tighten against the rear bearing causing binding.
gubbs3 is offline   Reply With Quote
NEED SUGESTIONS!!! J.JOHNSON Electric On-Road 7 06-22-2007 12:52 PM
looking into buying MT used around $200....sugestions? xxx-ntad2 racer Monster Trucks 13 05-25-2007 10:33 PM
car sugestions yahyahyahyah123 Rookie Zone 9 09-13-2004 01:40 PM
I need sugestions.... Juan C Munoz Electric On-Road 9 06-17-2004 08:10 PM
