No Fuel to Engine
I can't seem to get any fuel from the tank into my AE .15 Engine. I don't know why but every time I go to roto start it, no fuel goes through the line and into the engine. I even tried switching carbs. I even tried my old fuel tank, but that didn't even work.
Any ideas?? |
Originally Posted by David Day
(Post 3849546)
Any ideas?? it might be the little thing in your gastank that sucks up the fuel, try that, i know it has a filter or something, and maybe your is completely plugged? |
You know, I've thought of that, and since someone else has brought it up, i need to learn now how to get it out to check.
(Post 3849607)
try sucking very very lightly on the hose that attaches to the carb with an empty tank and see if you can get air through, make sure not to get gas in your mouth (duh) im betting its that little thing inside the gas tank |
Before you do any of that...
Have you tried blowing on the pressure line. That should send fuel to the carb. If not, check for a split fuel or pressure line. |
Originally Posted by Turbine_au
(Post 3849679)
Have you tried blowing on the pressure line. That should send fuel to the carb. If not, check for a split fuel or pressure line. split fuel line would be obvious... youd see fuel for like 1 inch in the tube, then it stops and theres fuel everywhere... its possible though |
None of that worked, I get good air flow through both the pressure line and Fuel line. I wonder if it's my carb??
(Post 3849841)
ok, one of my friend .28 engine also facing this thing. I try to blow air in from pressure line but it cant go into carb, but if I OPEN the throttle then the fuel easyly go into carb, is this mean the carb is BAD? Please advise.
Take the pres. line off the tank and try to blow air into the
exhaust pipe. If you can't then the nipple on the pipe is clogged up. Use a wire or paper clip to clean it out then squirt a little solvent through the nipple. |
Originally Posted by rageworks
(Post 3928961)
