Old 11-12-2007, 02:06 PM   #91
Paradoxmaker's Avatar
Originally Posted by Paradoxmaker View Post
Yeah the back one is the Himoto and the front of course is Jconcepts...
Paradoxmaker is offline   Reply With Quote
Old 11-12-2007, 04:13 PM   #92
DR ZAIRUS's Avatar
Originally Posted by DOMIT View Post
Not exactly... Any airfoil (even a flat plate) has an "angle of attack" at which it will "stall" (create turbulent flow over the curved portion) which kills lift (or in this case, since we are dealing with an inverted wing with the camber on the bottom) it kills downforce. For most airfoils, that angle is somewhere between 12 and 15 degrees of angle.
So, you mean that if we put the wing at an angle bigger than 12-15 degrees it starts dragging (robbing the car of speed?) instead of just pushing the rear of the car down??
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
TEAM www.fisio-sport.com
(Valencia, Spain)
DR ZAIRUS is offline   Reply With Quote
Old 11-12-2007, 05:52 PM   #93
rltanner's Avatar
Did you dye those or paint them
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 11-12-2007, 06:59 PM   #94
It's dye
I used clear 3m packing tape to mask off the stripes and dropped em in the dye...As long as you have good tape, an oil free surface, and no creases in the tape edges the dye doesn't seep under the tape.
Old 11-12-2007, 07:01 PM   #95
rltanner's Avatar
Cool how long do you leave the wing in the dye the longer the darker the color gets
Mugen MBX6
Mugen MBX6 Truggy
Old 11-12-2007, 07:13 PM   #96
10 to 15 min is usually good.
Old 11-12-2007, 07:24 PM   #97
rltanner's Avatar
Cool im going to try that on my new wings for the new season im changen my colors to RED,BLACK,WHITE cool colors i like them
Mugen MBX6
Mugen MBX6 Truggy
Old 11-12-2007, 10:56 PM   #98
MassiveMods's Avatar
Hey All
I dont want to take sides but we have tested these wings in a liquid flow bench as well as a wind tunnel in germany it cost us over 3 million dollars to test toy car wings. The test was done by none other than Daild Carlson who is an ex aeronautical engineer for Nasa. I say EX because he quit and then forgot everything he knew. He once owned 50% of Microsoft and is directly related to Elvis Presley !
the results are top secret so dont tell anyone !
Engine development manager Rifling Pty Ltd. Nitro fuel designer : Neo + World record title holder 2012 Austalian Nationals 147.6 KPH , 1 st 2 nd and TQ Australian National Buggy titles 2012. Victorian State title 2012 Neo + , South Australian state title ON and Off Road 1/8 2012 Neo + :-) QLD State Titles 2012 1st buggy & trruggy + TQ Neo + MG66 RX7 1st Sportsman Class Truggy QLD State Titles 2012 !! Nitro Addicts Australia . com
MassiveMods is offline   Reply With Quote
Old 11-13-2007, 12:48 AM   #99
What results are we supposed to keep secret? You never posted any.
kmorast is offline   Reply With Quote
Old 11-13-2007, 02:21 AM   #100
asw7576's Avatar
Originally Posted by MassiveMods View Post
Hey All
Ohhh ... I see , you mean that wing, right ???
Anyway, here is the latest .... Boeing, Airbus, and Mugen Seiki are developing new rear wing to increase downward airflow while reducing thermal wind flow signature. Hopefully the new design will increase top speed & downforce at the same time. It is known the Delta Phi Sigma of the angle of attack of the wing will transalate into fuel ecnomy as well. Such hybrid design will be nominated for 2008 noble prize in aeronautical technology.
Old 11-13-2007, 02:51 AM   #101
You forgot to mention that they are also good for the environment. I've been told they reduce green house gases by 10% when run on Mugens and 50% on the Airbus A380.
Old 11-13-2007, 08:31 AM   #102
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Yes, that is EXACTLY what I mean. Angle of attack = angle to the relative wind (direction of travel.) Anything over about 12-15 degrees AOA and the wing stalls. A stall is where the airflow does not stay attached to the cambered wing surface, instead becomes turbulent and creates drag without lift.
The Himoto and Proline wings APPEAR to be designed correctly. The Jconcepts one is not. The slotted portion of the wing re-energizes the airflow, allowing it to remain attached on the rear portion which is at a much greater angle- the first part of the wing turns the airflow somewhat, so the AOA limit there is different. Sounds silly, but it is really how it works.
The Jconcepts wing is depending solely on reaction against the upper surface, like a regular parachute. The others SHOULD actually be generating lift (in reverse, so it is downforce) off the lower surface as well, although the way they are molded at the front leaves a bit to be desired... I'm not sure if the ridge along the front causes it to trip the boundary layer to help the airflow stay attached, or causes TOO MUCH turbulence and kills the lift. I'd have to see it in a wind tunnel to know for sure, but I suspect it may be the bad effect and not the good one. None of the manufacturers is putting much real thought into the aerodynamics of those wings!
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 11-13-2007, 05:34 PM   #103
DR ZAIRUS's Avatar
Food for thought!! Hmmmm!!
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
(Valencia, Spain)
Old 11-14-2007, 12:21 AM   #104
Trader Rating: 52 (98%+)
when I was running K2 with stock kyosho wing (2 days a week almost every week) 3 yrs ago, I can feel a difference bwtn different wing mounting angles when jumping a long triple. With a higher wing angle, the front end stays up more than a flatter wing angle while in the air. The buggy feels more neutral and easier to drive with flatter wing angle.
so what kind of effect will a high down force wing do while the buggy is in the air? and on the ground? Thanks.
Lots of RC Stuff
straightaway is offline   Reply With Quote
Old 11-14-2007, 12:54 AM   #105
asw7576's Avatar
I thought you like banana better ? j/k
New JP-3 pipe, High force wings and tires plus more Vinatge R/C Items: For Sale/Trade 7 06-06-2008 05:07 AM
Himoto High Down Force Wing v2 MadRacer Nitro Off-Road 6 03-24-2008 11:50 PM
6 NIP HIMOTO HIGH DOWN FORCE WINGS HECTICRACER R/C Items: For Sale/Trade 12 07-29-2007 04:10 PM
2 NEW PROLINE HIGH DOWNFORCE WINGS $22 SHIPPED HECTICRACER R/C Items: For Sale/Trade 7 05-22-2007 10:20 AM
Recommended ESC & High Torque Servo for Kyosho Twin Force 4x4 rcmaster.net.au Australian Racing 1 04-06-2004 09:10 PM
