Old 11-07-2007, 06:21 AM   #1
layedbackguy's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to layedbackguy
Default Losi 8ight buggy and Truggy Clutch problems
Im sure this has been asked in the Losi 8 build tread, but i changed my clutch setup to the KH alumi, with the stock springs. For the 1st. 3 mins, the motor hits hard, but once it gets hot, it seems to drag the motor and has no pop out of the corners or for big jumps. I changed back to the stock carbon-alumi setup and it's strong all the way through a 20 min main. What springs should i use with the KH????
layedbackguy is offline   Reply With Quote
Old 11-07-2007, 07:17 AM   #2
For the 8ight 2 gold and 2 silver and 8ight T all silver with KH or any aluminum shoes for that matter.
gasser is offline   Reply With Quote
Old 11-07-2007, 08:25 AM   #3
kevinmajor's Avatar
Did you install new springs when you installed new clutch shoes? Old springs will lose their effectiveness because of the constant heating and cooling. So, as a general rule, I use new springs when I put new shoes on. Also, clean the inside of your clutch bell with some motor cleaner and a scrubby pad (the carbon shoes will leave some build-up that will affect engagement of the new shoes.)
kevinmajor is offline   Reply With Quote
Old 11-07-2007, 11:44 AM   #4
Well for the buggy i did use gold and silvers and it worked pretty good, but i didnt try all sliver on my truggy....Thank you .. i will try that.
Old 11-07-2007, 11:46 AM   #5
Yes it was a brand new clutch set up i installed, and after 2 heats the motor just wouldnt get up and go. I will clean the bell out as i did see the carbon build up on another clutch bell i was running.....Thank you so much for all your help.
Has anyone ever used all carbon shoes? If so what was the result, or what would the results be?
Old 11-07-2007, 11:53 AM   #6
cornerspeed's Avatar
I've been running all 4 carbon shoes with 4 gold springs. I love the way it feels and how long it lasts. I have the same shoes and springs for 3 gallons with hardly any wear. I also think there is less heat and helps with clutch bell bearing life.This for the buggy. I don't have a 8T, so I am not sure on the set-up there, but I've heard 4 aluminum shoes with 4 silver springs.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 11-07-2007, 12:27 PM   #7
Cool, i want to try the all carbon because i did think about the heat and the clutch bearing. Are you using the losi carbon, or something else? Sorry for all the silly questions, but i just need to get this buggy and truggy running good so i can do go this winter....thanks
Old 11-07-2007, 12:43 PM   #8
Lars Johnson's Avatar
Send a message via AIM to Lars Johnson
Is there another company that makes carbon shoes for the Losi clutch? i'm not sure to be honest.. I'm running the same setup on my 8 as Don tho, 4 Losi carbons/Gold springs, and i like it a lot. one thing you want to keep an eye on is the inner bearing, because of the fine carbon dust that can get in the bearings and chew them up. I've only got about 2 gallons on this current clutch, but i dont remember the last time i changed bearings... keep em clear of alum & carbon dust, and they'll last a Long time.
I also run all Alum's (Losi Long-Wears)/silver springs on my 8-T, and i've had the same shoes/springs on that beast for a few months now. it's gone thru qualifying and 30-min mains at both a Minnesota Nitro Series race and the Reedy Truck Race. I think, as a rule of thumb, if you monitor all parts of the Losi clutches a little closer than others, the lifespan will greatly increase. Taking a few mins to clean the dust outta the bell, cleaning the bearings and making sure everything is shimmed correctly is a lot more exciting than dropping $40-50 to rebuild everything.
Team Associated / Reedy / AKA / Futaba / OS Engines / Byrons Fuel / www.steelescycle.com
Lars Johnson is offline   Reply With Quote
Old 11-07-2007, 05:56 PM   #9
Yes, Losi carbon shoes.
Donny Vinkemulder
TLR Driver
Old 11-13-2007, 12:31 PM   #10
For Sale a Brand new set of Team Losi Eight Shocks.
These are Brand new, built but never run. Along with the Shocks will
come extra springs, o-ring set, 2 new sets of Shock Piston's, one new
set of Rear Shock Body's, New set of Shock caps, Shock Adjuster nuts,
and rear Shock Shafts. All spare parts are new, still in original
packaging. I am asking 60.00 shipped to the lower 48 states. If you
have any questions or would like to see pics email me at
Jon@vgsportsinc.com
IMTK422 is offline   Reply With Quote
Old 11-13-2007, 12:52 PM   #11
air8's Avatar
DUDE, there is a for sale thread on this site.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 01-14-2008, 07:49 PM   #12
Old 01-14-2008, 09:19 PM   #13
air8's Avatar
So layedback, what's your problem with the clutch?
--"U Ain't Fast!!"
Chris Pearce
Old 01-15-2008, 05:29 AM   #14
No problem with my clutch, wanted to bump this back in action for anyone that is having problems. good info here
Old 01-15-2008, 04:51 PM   #15
So did you ever try the 4 carbon shoes set-up for your buggy?
Donny Vinkemulder
TLR Driver
clutch assembly for losi 8ight rtr buggy playboy Nitro Off-Road 3 12-20-2007 02:41 PM
***** TEAM LOSI STARTER BOX FOR BUGGY AND TRUGGY 8ight 8T 8ight-T ***** mach51 R/C Items: For Sale/Trade 2 11-27-2007 11:43 AM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
Losi 8ight Buggy Clutch--Dumb Question Chuck67 Nitro Off-Road 6 08-23-2007 05:28 AM
WTB clutch pins for Losi 8ight buggy!! 8ightTJ R/C Items: Wanted to Buy 0 05-03-2007 06:53 PM
