stock head shim for V spec >
Old 11-14-2007, 06:37 PM
Trader Rating: 52 (98%+)
Default stock head shim for V spec
Hi,
What is the stock head shim for the V spec motor? I opened one up, there is a 0.25 mm and a 0.1mm, is that the stock? there is also an extra 0.1mm, should I add that for running 30%? Thanks
straightaway is offline
Old 11-14-2007, 09:36 PM
SkarTisu's Avatar
If you got a brand new one out of the box, then the spare copper shim can be used for break-in, but it's not necessary to use it after break-in on 30% fuel.
SkarTisu is offline
