Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-07-2009, 12:22 PM   #5686
Sam-E's Avatar
Originally Posted by Merciless View Post
I guess you still use the futaba connector to connect the battery to the switch ??
If so that must be just as likely to fail as mine, I just don't have a switch in there also ....... which might fail.
The thought process is ........ If it don't have to be in my buggy, It ain't gonna be in there.
Rod
With that thought process, ditch your exhaust..
Caster MK2 Grenade - 2010 Off-road World Champion!!!
Nitro-X - Extreme Racing Fuel!
Sam-E is offline   Reply With Quote
Old 11-07-2009, 04:22 PM   #5687
would be good if the rules didnt require one and if the engine would actually work better without but i doubt it.
I used to use a deans connector on the 5R, i mounted the female part to the switch mount in the battery box so all i had to do was plug it in and go the female part was direct to the pack and the male was attatched to the receiver, i was going to look at the same sort of system but with the switch on top its a bit harder to sort out or just doesnt look as nice
MBX5R, OS V-Spec, Sanwa, model technics fuel
a great wife
and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 11-07-2009, 04:33 PM   #5688
Merciless's Avatar
Send a message via ICQ to Merciless
Your not very clever are you
Rod
Merciless is offline   Reply With Quote
Old 11-07-2009, 05:03 PM   #5689
I know it's out there somewhere...someone have the link for the pdf. file on the set-up sheet for the mbx6
lovell is offline   Reply With Quote
Old 11-07-2009, 05:20 PM   #5690
Blank
http://www.mugenseiki.com/images/mbx...e0801blank.pdf
Kit
http://www.mugenseiki.com/images/mbx...t-e0802kit.pdf
M-Spec
http://www.mugenseiki.com/images/mbx...t-e0901kit.pdf
a great wife
and lovely kids
Old 11-08-2009, 03:02 AM   #5691
Dude. That is a sick setup. I may have to try something like this. Hats off to you.
Revooooooo is offline   Reply With Quote
Old 11-08-2009, 01:02 PM   #5692
Thanks for the link to the set-up sheets...is there one that you can edit out there?
Has anyone tried 8 hole pistons in their mbx6 yet...i like how the 6 hole work and thought about making a set of 8 hole with 1.2mm or 1.1 holes?
C.R.
Old 11-08-2009, 03:16 PM   #5693
mattwoodcraft's Avatar
i have done 8 holes with 1.3 mm made the buggy very consistant and seemed better through the rough sections worth a shot for sure , had to play around with shock oils a little more but
RYPER HOBBIES ~ PURPLE RUSH FUEL ~AKA TYRES
GO TECH MG66 ~ BCE CHASSI
X-ray 808 09 spec
mattwoodcraft is offline   Reply With Quote
Old 11-09-2009, 07:30 AM   #5694
Default pins in the diff
hi guys,
this is a long shot but i lost 1 of the pins that go into the diff cup for the bevel gear.
its tiny and i cant seem to find it in the work pit/ bench
anyone has one??
thanking in advance
muaythai is online now   Reply With Quote
Old 11-09-2009, 11:37 AM   #5695
gixxerman's Avatar
Is there a way to identify X-6 springs that are missing the spring rate tabs?
www.altoonaraceway.net
gixxerman is offline   Reply With Quote
Old 11-09-2009, 05:06 PM   #5696
OfnaJoe's Avatar
Calipers, measure the thickness of the wire!!
Team Terribles \ Mugen MBX6(B&T) \ BCE\Novarossi\ H.E.S.\ Bryons Gen2\ Hitec
OfnaJoe is offline   Reply With Quote
Old 11-09-2009, 06:35 PM   #5697
if you are looking at the end of the spring...hold the cut/ ground end of the spring at 12:00...while holding the spring...look at the bottom and see where the cut/ground part of the spring is and it's just like a clock...if it's at the 15 min. mark it is the .25 spring and so on...if it is at the 45 min mark it is .75...
Old 11-10-2009, 04:10 PM   #5698
count the coils, the first number on the tag is the amount of coils. more coils are softer springs.
o.s. power is offline   Reply With Quote
Old 11-10-2009, 07:08 PM   #5699
gixxerman's Avatar
They are all the same thickness.
Old 11-10-2009, 08:22 PM   #5700
Yep, calipers won't help. I slide colored heat shrink on each matching set of springs. Then write down what spring rate each color is. You can count the coils, but it's easier for me to use heat shrink.
Thanks to:
www.mugenracing.com
www.TnT-fx.com for all your design needs
www.morganfuel.com
s porter is offline   Reply With Quote
Forum Jump
mugen mbx6 lets talk about it! ercerc8 Nitro Off-Road 1 08-31-2008 09:09 PM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen 5T Chassis, Mugen 46 Tooth Pinion, Associated Ride Height Gauge bretzkej R/C Items: For Sale/Trade 1 08-19-2007 05:31 PM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 04:45 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
