Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-18-2009, 05:33 AM   #4006
Originally Posted by Davidka View Post
I don't see how that linkage setup offers anything over the stock setup. With that setup you have to worry about the linkage hitting the tank/splash guard.
Apparently you have small thin fingers if you dont have a problem adjusting the brakes with stock setup. Or you have never had your buddy hold the transmitter while you adjust the brakes-then hit brakes and pinch the hell out of your fingers. With this you have F/R rods up top with knurled adjusters instead of the smooth collars- no tools reqiured to adjust. It doesnt hit the tank but I did have remove a small amount of the splash gaurd at the very back-the previous owner had already done this with the stock setup. But it still keeps the fuel off the front brake which is the whole reason for the splash gaurd to begin with. I will post more pics in the next day or 2 to give you better idea.
JonnyW is online now   Reply With Quote
Old 06-18-2009, 06:40 AM   #4007
Lonestar's Avatar
Originally Posted by smracer31 View Post
http://www.amainhobbies.com/product_...Mayhem-Pro-RTR.
Anybody find a suitable replacement for the rear outer hinge pins, both mine bent like twigs and im currently using kyosho pins as replacements but they are about 3mm to long.
Same as the dynamite, it seems, eh?
When the drops, the BS stops.
"Ma Grand'Mere est enfermee/Dans une boite de Chicoree/Quand la boite s'ouvrira/Ma Grand'Mere sortira"
Lonestar is offline   Reply With Quote
Old 06-18-2009, 01:52 PM   #4008
Default front servo
hey guys, just about finish building my mbx6t and in the manual it is recommended that one places a plate between the screws and the graphite radio try to lift the servo slightly higher.
only in the steering though, but not for the throttle.
suprise the buggy, it is not mentioned in the manual.
i have driven about 1 gallon in my buggy without any problem.
just checking how many of u there put a plate?
muaythai is online now   Reply With Quote
Old 06-18-2009, 02:27 PM   #4009
Integra's Avatar
some servo's have larger dimension's which would require a shim to get the servo up and off the chassis....check for clearance and if your good you dont need a shim.
Blue Groove Apparel - Hitec - Losi - W.E.D. Paint - Byrons Fuel - O.S. Engines - Tekin - Futaba - Clockwork Engines Team Driver - Matrix Concepts.
Integra is online now   Reply With Quote
Old 06-18-2009, 02:31 PM   #4010
Mugen9112's Avatar
Send a message via AIM to Mugen9112
Can anyone comment on using 7-5-2 in the diffs? How does it feel and what kind of track does it work best on? Thanks.
Mugen MBX6T w/ O.S. Speed
AE Factory Team B4 w/ Tekin Setup
Mugen9112 is offline   Reply With Quote
Old 06-18-2009, 02:55 PM   #4011
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I used the spacers on the MBX6 & MBX6T. I use it for clearing the servos off the chassis and also on the brake/throttle servo to keep the brake/throttle linkage parallel and evenly spaced on the servo horn. Each brand servo is different, so you have to check them installed to see if they need raising.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 06-18-2009, 03:59 PM   #4012
7-5-2 is great on a clay indoor layout. A bunch of us ran that all winter.
Outside, it just didn't seem to work very well. I think the 7 in front made the car too unpredictable.
071crazy is offline   Reply With Quote
Old 06-18-2009, 05:07 PM   #4013
Thats what i ran my last race on an outdoor clay track...i love it...won the race as well with a lap on the field...
I thought the car felt more predictable honestly
Tons of on power steering, you lose a little turn in but honestly it was not enough for me to care. I would try if you have not.
pl_unc86 is offline   Reply With Quote
Old 06-18-2009, 06:25 PM   #4014
Default LINKAGE/BRAKE MOD
Some new pics of the finished mods. You can see what I was talking about cutting the throttle side of the cams. Also I you can see the marks on the back of the pads where the stock cams actually apply the brakes when you apply the gas. You wieght weenies can even remove all but one side of the cam to save a few grams. I had to bend the cam levers up to clear the KH top plate. The carbon disc fit tight to the outdrives so they are not full floaters yet, need a tank to lossen every thing up for final adjustments. Also added Ofna brake springs to keep the pads off the discs. Hope this helps with any ideas anyone may have had.
Old 06-18-2009, 07:49 PM   #4015
Mugen9112's Avatar
Thanks for the response. Do you recommend this kind of diff setup for running on a slightly dusty, hard packed, higher traction track?
Old 06-18-2009, 08:17 PM   #4016
ezveedub's Avatar
Yes. Car will have even more steering both on and off power. Make sure you use the correct tires, that is the key, not swapping diff oils.
Old 06-18-2009, 08:42 PM   #4017
yoshgixxer's Avatar
Trader Rating: 46 (98%+)
7-5-2 is the SHIZZNIT!
i seen ezvdub posting it a few pages back so i slaped it in there..as i had no were else to start! i honestly see no need to stray from this..i could stay on the gas alot longer through the corners then i could with my 8ight 2.0! thats for sure..i actually set the TQ pace for the day in the first qualifier first time ever driving the car...ended up 2nd in the main..the car settles down very fast too with this oil set up
Team Caster USA
www.casterracingusa.com
answer-rcusa.com
Max-amps
yoshgixxer is offline   Reply With Quote
Old 06-18-2009, 10:13 PM   #4018
rcejk's Avatar
Send a message via AIM to rcejk
Has their been any issues with the center diff leaking? Ive noticed that my center diff has been leaking around the bearings and i replaced the o-ring inside the diff case and after a run or so i noticed it leaking again. Should i look at getting high temp o-rings?
Torco Racing Fuel, Team Srs, Team Terribles
rcejk is offline   Reply With Quote
Old 06-18-2009, 10:46 PM   #4019
arm2storm's Avatar
Trader Rating: 15 (100%+)
Nope, it's probably just over filled make sure the diff fluid is right at the cross pins and not over them. If you over fill them the fluid finds a way out.
arm2storm is offline   Reply With Quote
Old 06-18-2009, 10:50 PM   #4020
rcejk's Avatar
Thanks, ill rebuild it and see how it goes from their.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
dikyh , markfanelli
Forum Jump
mugen mbx6 lets talk about it! ercerc8 Nitro Off-Road 1 08-31-2008 09:09 PM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen 5T Chassis, Mugen 46 Tooth Pinion, Associated Ride Height Gauge bretzkej R/C Items: For Sale/Trade 1 08-19-2007 05:31 PM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 04:45 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
