Mugen MBX6
has any one had success with the losi bladder and foam compensator in the mugen shocks?
Guys I have a shock rebound question .on a loose bumpy tracks what do you set ya shock rebound to ? I have always set at 100% rebound is that right or wrong ? Thanks in advance .
Hi, is the 6 and 7 suspension arms, and fuel tanks interchangeable? I have both the cars and need to take a decision to buy spares. Any help will be appreciated.
has anyone trey the mbx7's rear end in the mbx6??
Anyone using the M2C racing 3-piece engine mount on the mbx6? i want to get one for my x6 but the description on amain website is not that clear whether i can use it with the nova engine specifically the toro nero. Any heads up guys?
Oh btw, i emailed m2c a week ago buy haven't got any reply from them.
Thanks a lot for any help i can get.
just ordered the Tapered pistons, which is tapered up and which is tapered down. Also which side up should I be installing them.
I have a personal idea of what should be customer service and when I send an email to a shop or a brand and they feel like not answering, I then feel like not giving them my hard earned money.
For those of you who have a MBX6R, or have the E0185 aluminum rear arm mount, have you guys figured out the combinations for the inserts? You get three: A, B and C. Looking at the diagrams, it tells you what combinations gets you what, but it doesn't really specify the letter of the insert. Inserts A and B could be the same. Only the C insert with the notch in the middle can't be confused with the others.
Am I missing something obvious?
just finish swapping complete MBX7 drivetrain in my 6...
interchangble MBX7 parts involve
3 pcs E2201 DIFF CASE
2 pcs E2202 CONICAL GEAR Front/Rear
2 pcs E2204 BEVEL GEAR Front/Rear
1 E2206 GEAR SPUR
will post sum photo soon...
1 E2206 GEAR SPUR
I use the fioroni and in it you can put whatever engine, I have spare engine mounts on 3 engines ( nova P4, OS,Alpha ) and all fit perfect.
awaiting your photos and feed back on how much it improves the handling of the x6, thanks a ton for sharing
mbx6 swap mbx7 drivetrain
centre diff........................
Front Rear.............................................. .
helical vs straight cut gear
mbx6 diff gear set fit well inside mbx7 diffcase
also fit well inside gearbox case without any modification...
before. mbx6
after. mbx7
Gain some improvement but not too much... character and feeling also change a bit...
Quicker acceleration smoother entering and exit the corner...
Fuel Run-time - Not testing yet..
before. mbx6
after. mbx7
shajohan, nice work man, thanks a lot for sharing, please tell us more about the upgrade, i've heard lots of good things with the x7's handling, and if the gearing contributes most of the improvements over the x6, then what you've been doing might save a lot of cash for the x7 just for better performances. And of course i'll also go this route for a smaller budget(cuz i don't have the budget for the x7, hehe).
