Old 11-04-2007, 04:58 PM   #1
Trader Rating: 14 (100%+)
Default mbx5t rearend drops while on power. help!!
just put my mbx5t together, stock, when on power rearend runs lower than the front(squats). seems to take some steering away. rear end seems soft with stock set up. any help would be great.
jlo
jlo8864 is offline   Reply With Quote
Old 11-04-2007, 05:15 PM   #2
Trader Rating: 24 (100%+)
What oil and pistons are you running in the shocks ? And what is you peload on the rear shocks ? The rears bones should be level or close to it, we will run just slightly above level if we have good rear bite exiting the corners. we run 1.5 (black) pistons all the way around and 400 Mugen oil in all 4 most of the time.
Jeff Ford is offline   Reply With Quote
Old 11-04-2007, 05:54 PM   #3
asw7576's Avatar
And add more or thicker shim on the spring collar.
Old 11-04-2007, 06:12 PM   #4
i'm running 400 all around with the 1.4 pistons, it seems soft, wouldn't it be softer with the 1.5's, i have been running bones level., i figured more preload would just raise ride hieght.
jlo
Old 11-04-2007, 06:57 PM   #5
Drill the piston's out to 1.5mm, it will help a lot. I wouldn't worry too much if the back sqauts while accelerating, mine does, and Ford's does to, jsut the natural response from acceleration.
-Steve
Steve Thyen is offline   Reply With Quote
Old 11-04-2007, 07:11 PM   #6
kevinmajor's Avatar
You could also play around with anti-sqaut vs. pro-squat and see how you like the way it affects handling. Pro-squat will not drop as much during acceleration but my not handle bumps as well.
kevinmajor is offline   Reply With Quote
Old 11-04-2007, 07:50 PM   #7
Registered User
Take some of the droop out of the front of the Truggy, I think the stock setup has too much, the front lifts too high on power and u lose steering i would not worry about the back.
You could try adding more anti-squat if youl like.
Loop&Roll is offline   Reply With Quote
___________________MUGEN MBX5T PROSPEC TRUGGY w/ MAX POWER MOTOR__________________ rmargiotta R/C Items: For Sale/Trade 5 12-03-2006 09:52 AM
tribotech power matrix com drops Shadows Australia Wanted to Buy 1 09-15-2006 01:34 AM
Peak Power drops Snikkari Electric Off-Road 4 08-11-2004 09:22 AM
team orion speedy drops/other com drops acid_rain182 Electric On-Road 3 06-25-2003 10:16 AM
Peak Racing Power Drops! - TRC Foams doublest Electric On-Road 2 05-18-2003 12:31 AM
