Twin mp777 speed results
Did a few speed runs today.Was very happy with the results considering the 22t clutch bells didn't turn up in time and the radio gear started glitching so we had to stop early. Both engines were running at an equal but low 178f so further tunning is required. Anyway here is the video.
video here
Chris
video here
Chris
Daaamn thats insane, look forward to the 22t
that is freaking nuts i LOVE IT skip 22 tooth clutch bells!!!!!
run 25 tooth clutch bells CEN makes a HARDEN STEEL pinion gear thats 25 teeth and it mounts on the HPI threaded clutch bell
im running that on my losi 8 with a revo 36 tooth spur gear where the center diff would be
if my novarossi 528 could push that gear u shouldnt have a problem i think u might see alot more than 80 MPH
cheers chris
here is a link to the pinion gear
http://www.minirccar.com/index.asp?P...ROD&ProdID=373
ull also need the HPI RS4 3 threaded clutch bell, everything will drop right in
you can use this: http://www.southeastrc.com/Items/Std...ookup=LOSB3340 and just screw the 25 tooth on. and get some spacers for it so it will mesh in the right place.
a clutch bell is a clutch bell all of them are the same size exept the ones on the old RC10GT
i have that clutch bell on every car i own with a 3 shoe clutch trust me it works
does the pinion screw onto the inner or outer part of the bell or can you get a single speed clutch bell
chris
chris
Sorry but this is not true. I bought a 17t bell off ebay and when I got it it was for a Tmaxx and it will not work. I believe it was because it was for a small block. Not sure why but they are NOT all the same. Though most are interchangable. Not trying to start a battle. Just didn't want anybody getting bad info and wasting money as I did.
the reson i sayed the CEN pinion gear is becuase it wont strip with the metal spur gear becuase its harden steel
