Old 11-24-2007, 01:29 PM   #31
Originally Posted by MiamizFinest View Post
well......i know ur clutch will be fine and it will not BOG OUT
ur 777 will be useing a 22T on the bell and 47 on the spur right??? well my inferno gt is running ur same diff ratio and im running with ONE motor 25T on the bell and 36T on the spur gear (revo spur gear)
my clutchs have help up fine and the motor does not bog out........yes the motor struggles a little to pul the car from 0-20 MPH (not that bad actually) but from 20 to 75 mph it gets there pretty dam fast
with ur 2 motors trust me ull pull any gear ratio ud like........if u eve wanan rip out the center diff and run a str8 shaft with a small spur gear let me know ill show you how to do it
Just out of interest what is the diameter of the wheels you are using on the inferno gt.
The spur is a 46t on the 777
Chris
chris52 is offline   Reply With Quote
Old 11-30-2007, 08:57 AM   #32
MiamizFinest's Avatar
Trader Rating: 37 (100%+)
i use OFNA FOAM wheels and there exactly 4 inches tall when new.....
-= Made In Dade =-
MiamizFinest is offline   Reply With Quote
Old 11-30-2007, 02:17 PM   #33
Well that would explain a bit why your car can handle such an extreme gear ratio. The wheels i am using are 5 inch.
chris
Old 11-30-2007, 06:17 PM   #34
yea but its a big plus even tho i loose and inch of tire height the wheels are alot lighter than any rubber wheel.......ud serously notice a big pick up from rubber to foam......try it out jsut make sure u get the BLUE compound those are the hardest and last the longest
-= Made In Dade =-
Old 12-01-2007, 02:33 AM   #35
I've never actually used a foam tyre, but i can see how they would make a big difference.The thing i like about rubber is that they balloon, so a tyre starting off at 4.5" at low revs gives you better acceleration, but when the revs and speed pick up the tyre will ballon to aprox 5" to 5.5". This kinda give's you a the same effect of having a 2 speed gearbox if you see what i mean.
Chris
Old 12-01-2007, 11:01 AM   #36
ur 100% right but jsut switching to the foams ull notice how much lighter they are and how much quicker ur car will pic up.......
about the balloning u can make up for that with taller gearing id help you out set it up
-= Made In Dade =-
Old 12-01-2007, 03:31 PM   #37
Dave_x8's Avatar
Send a message via MSN to Dave_x8
wicked buggy you got there mate.
Dave_x8 is offline   Reply With Quote
twin mp777 now even more power chris52 Nitro Off-Road 15 07-29-2008 06:01 PM
Twin RB C6 Kyosho MP777 chris52 Nitro Off-Road 23 10-24-2007 08:08 AM
My Misbehavin' RC Speed Results for Team Losi 8ight. lanerbrainer205 Nitro Off-Road 49 08-06-2007 02:32 PM
Twin Serio .27 Twin Super Charger Doublede12 Monster Trucks 4 01-22-2005 09:19 PM
Speed Tech R/C Racing Results are available online now! SpeedTech Racing Forum 5 12-09-2001 06:59 AM
