Old 11-02-2007, 09:56 AM   #1
Larcor69's Avatar
Trader Rating: 23 (100%+)
Default Novarossi P5X
I have a p5x hot modded, I just had pinched, I also put new bearing's in it and I lost the head shimm's, so I got new one's,The question I have how much should I shimm the button running 30% O'Donnel fuel?? anybody know?
TLR, FUTABA, BLAZER MARINE, VOODOO PROPS.
Larcor69 is offline   Reply With Quote
Old 11-02-2007, 11:09 AM   #2
rabidsquirrel's Avatar
I'm not sure what shims I have in mine, but it's been working great on 30% for some time now - ever since I got it.
I would email or call Fusion - the new novarossi US distributor, and ask them...
rabidsquirrel is offline   Reply With Quote
Old 11-02-2007, 11:19 AM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I believe its a .20mm shim up to 25% Nitro and add a .10mm shim for 30%. You really need to check the shim thickness that your installing to make sure. Novarossi has a mutlitude of different thickness shims. The main thing is detonation. If get no detonation as is on 30%, you should be OK.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 11-02-2007, 11:34 AM   #4
Larcor69's Avatar
the shimms I got are .10/.004 5 in total was thinking of using 2 of them
Old 11-02-2007, 03:20 PM   #5
22Racer's Avatar
Trader Rating: 67 (100%+)
They usually use 1 or 2 aluminum (they are thicker probably around .01 thousandths) and one copper, Do not use just 2 .004 shims!
Use a caliper, measure down from the top of the sleeve to the piston at top of stroke. (make sure sleeve is down all the way) Then measure the head button from the bottom(part that goes into the cylinder) to the seat where the shims go. The head button should measure .026 less than the cylinder measurement.
Rex
22Racer is offline   Reply With Quote
Old 11-16-2007, 03:47 AM   #6
v1r killer's Avatar
mine was running great out of the box and i only run 25% do i need to run 30% in it. it has power every where with a jp3 pipe or is there a better pipe to get more from this engine
Bruce ( JUICEY ) Airey
Tekno EB48-3, RX8.2 1900, NB48-3, Nova P5
Coast2Coastrc, SMC batteries, FTW Bodies; Tekin; AKA Tyres
v1r killer is offline   Reply With Quote
Old 11-16-2007, 04:27 AM   #7
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
mugen 1005 wich is now made by bullit racing
cheesecake is offline   Reply With Quote
Old 11-16-2007, 04:55 AM   #8
v1r killer's Avatar
much more power out of that or just better fuel time?
Old 11-16-2007, 06:20 AM   #9
ezveedub's Avatar
Rex
Your measurements are in inches for head to piston clearance, correct?
I just went over some data, and the P5X comes from the factory with 2x 0.30mm (aluminum) & 1x 0.10mm shim (copper). Please check this to make sure this is what you have BEFORE removing or adding any shims. Novarossi states this is for 25% nitro. My suggestion is if you removed or added shims, is to use the pinched solder method ahd check your head to button clearance before running the engine. In general, for 30% nitro with stock shims, add 0.10mm shim to the stack and that should be correct. I believe .024-.026 inch of clearance for 25% and .028-.030 inch for 30% nitro is the general rule.
Difference between Novarossi 51603 tuned pipe and Novarossi RB x12 tuned pipe? racer rich Nitro On-Road 8 11-06-2010 06:52 PM
FS: 1/8 Kyosho Evolva + .21 Novarossi 359 + Novarossi .21 pipe + Tons of spares WogBoy Australia For Sale/Trade 6 05-15-2008 05:32 PM
Novarossi Plus 21-5KT (Turbo Plug) New in Box, AND Novarossi 21P5XS less than 1/2 gal nobike R/C Items: For Sale/Trade 29 03-31-2008 11:00 PM
Novarossi N528XR and Novarossi EFRA-9853 For Sale BAMF90 R/C Items: For Sale/Trade 9 10-11-2007 08:29 PM
NOVAROSSI 367 PLUS 2 pink_sleeve Electric Off-Road 3 05-24-2007 04:20 PM
