Old 10-30-2007, 08:52 PM   #1
Default Rc car Stops running
I was tuning my carb today(RC10GT2) and it idles fine and has good take off power, but when I go to slow down by reversing the throttle the car dies. I have tried messing with the carb but no results. Any Ideas.
newguytoRc is offline   Reply With Quote
Old 10-30-2007, 08:59 PM   #2
kevinmajor's Avatar
Are you setting the idle by using the trim on your radio or the idle stop screw on the carb? Which engine is it? Have you checked the glow plug?
kevinmajor is offline   Reply With Quote
Old 10-30-2007, 09:23 PM   #3
I am using the adjustment on the carb. I thought the plug was the problem so I replaced it but still the same problem.
Old 10-30-2007, 09:37 PM   #4
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Make sure the throttle opening at neutral is the same when applying the brakes. If it moves, then your servo is holding the throttle open slightly and when you apply brakes, it closing and stalling the engine. The only other thing I know of is the mixture. If the engine mixture is running lean, it will try to continue to rev when you close the throttle, but you'll stall it with the brakes.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 10-30-2007, 10:32 PM   #5
that makes sense, because the took the car apart for a good cleaning and I didnt mark where the throttle mounted on the teeth. thanks
Old 10-31-2007, 04:58 AM   #6
Taylorm's Avatar
..............sound like carb is closing off completely.......or is a little rich or lean.........does engine spped up before dying?.......lean.........or does it just taper off and die?............rich...........make sure carb is not closing completely when brakes are applied.........and don't use trim to adjust carb or it will throw endpoints off........
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 10-31-2007, 05:11 AM   #7
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
If the engien is lod then it might be loose compression. I have one engine then facing this problem, running is fine but when I full throttle then let it idle the engien die itself. Have adjust max on the idle screw but no help.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 10-31-2007, 11:31 AM   #8
joe of loath's Avatar
90% of the time its this one...
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 10-31-2007, 05:14 PM   #9
Wildbillsphotos's Avatar
Trader Rating: 31 (100%+)
Send a message via MSN to Wildbillsphotos
Check the clutch springs, it sounds like the clutch it still engaged when you hit the brakes thus stopping the motor.
Life is too short - Hug your kid's often!
Adopt a pet and save a life!
Visit My Website: www.WildBillsPhotos.com
Mel's Shells-n-Sticky Things!
Wildbillsphotos is offline   Reply With Quote
Old 10-31-2007, 06:07 PM   #10
ezveedub's Avatar
More like check the clutch shoes. If they are soft type, they can mushroom on the ends and jam against the flywheel or clutch bell. But this is more likely to happen when accelerating on full power for a few seconds, not just short blips, unless its really worn out.
Old 11-01-2007, 06:46 AM   #11
how many gallons of fuel have you gone through you might need to replace some things
loveinferno is offline   Reply With Quote
Old 11-01-2007, 06:47 AM   #12
Exclamation
this is for you new guy to rc
Old 11-01-2007, 09:05 PM   #13
I havent even gone thru a whole gallon. I first bought a gallon of trinity fuel and used about half. I was away from my house but needed fuel so went to the local hobby shop and bought a small bottle of the odonnell racing gas and I still have some of that left. My only worry is that also when it idles it makes a clicking noise. It only did this after I replaced the pull start.
Old 11-02-2007, 05:38 PM   #14
rltanner's Avatar
thankz for the answer to a problem that was going to asked
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Timing you pit stops in longer mains, whats your method? pracy Nitro Off-Road 6 06-19-2008 09:15 AM
FORCE .25 PISTON STOPS AT TOP OF SLEEVE!!!!! HELP!! jatoman1992 Nitro Off-Road 16 10-03-2007 02:11 PM
E-maxx Cuts out and stops moving scrolanky Monster Trucks 3 07-03-2007 09:49 PM
car stops when i accelerate lachlan90 Nitro On-Road 1 02-02-2004 12:16 AM
