oils
Old 10-27-2007, 10:31 PM
Mugen MBX-5's Avatar
Default oils
for diff oil, whats the difference bewtween 5000 and 50,000.
is is really 10x stronger???
theres like 1000,2000,3000,4000,5000,6000,10000,50000, 100000. wtf??
Mugen MBX-5 is offline
Old 10-28-2007, 04:26 AM
joe of loath's Avatar
its the viscocity. the more viscous, the more 'locked' the diff is.
joe of loath is offline
Old 10-28-2007, 12:23 PM
yeah but why are the increments by 1000. then once it hits 10,000. it jumps to 50,000 and then 100,000.
the 100,000 is actually 100x more viscous than the 1000??
why would you want that??
can someone exlpain how this works, i have no idea about diff oils.
Old 10-28-2007, 12:34 PM
i guess the mumbers are times the viscocity of water. so say water drips (just making up numbers) 1000 times a minute through a 1mm hole, a diff oil with a viscocity of 1000 will drip once a minute. the stupidly high numbers are for larger scale cars like the HPI baja, because it needs a thicker oil in the diff becuase of the increased powerm, and car engine oil is measured in the hundreds of thousands.
Old 10-28-2007, 12:36 PM
slaytanic's Avatar
Trader Rating: 20 (95%+)
Without getting too technical, diffs work by transferring more power to the tires that are losing traction. So, look at the center diff. When you are on the throttle you may see your front tires baloon up. Thats because they are losing traction and the center diff is sending more power to the front. This actually slows your accelleration some. By putting a thicker fluid in the diff you slow this action down some and it keeps more power to the reaer giving you more bite. Too thick of a fluid though and you will get too much power to the rear causing the rear end to become loose and breaking free. This is cool if you want to do donuts but in racing you want to find a good balance. So, start with maybe 5k in the center and go up or down from there until you find what feels right. There is alot more too it than this but it will give you the idea. Do some reading and you will get it. Hopw this helps.
slaytanic is offline
Old 10-28-2007, 06:38 PM
hmm that makes sense. but is 100k seriously 100 times thicker then 1k?
and these were all mugen diff fluids. does that mean theyre made BY mugen or FOR mugen.
Old 10-29-2007, 04:11 AM
just made by mugen. you can use any fluid in any car, but they are all SLIGHTLY different. i beleive someone made a chart of shock fluid with the three main manufacturers on, and at the high end they were all miles away from each other.
Old 11-01-2007, 05:08 PM
DR ZAIRUS's Avatar
Yeah!! In buggies we usually use something like 3-5000 front, 5-10000middle and 1-3000 rear . I use 5-7-2. The bigger numbers are for monster trucks and larger scales.
You can use any brand in your buggie. They are all more or less similar, but there are slight differences between one brand and another. Check out the charts in www.TWF8.com.
DR ZAIRUS is offline
Old 11-02-2007, 05:18 PM
rltanner's Avatar
I asked the same question once before and I was told that the 100,000 and up 500,000 are for the on road cars
rltanner is offline
Old 11-04-2007, 12:04 AM
here's the chart http://www.morcc.com.au/images/fbfil.../Shock_Oil.pdf
sand_muncher is offline
Old 11-04-2007, 01:36 AM
Trader Rating: 28 (100%+)
You are correct. I normally run 30,000 in my rear diff in my onroad sedan. Lightest I have ever run is 10,000 and the heaviest I have ever run is 100,000.
Scott Fisher is offline
Old 11-04-2007, 08:21 PM
savage.25's Avatar
i have my rear diff ripped apart right now and a friend of mine is using the ofna racing silicone oil 50,000 weight, which is what one of my local hobby shops are running and they've never blown up a diff. so thats what im going to be running..
savage.25 is offline
