Old 10-26-2007, 04:38 PM   #1
ollie 45's Avatar
Trader Rating: 18 (100%+)
Default fuel line/zip tie?
This is kind of a stupid question but what is the easiest way to put fuel line over your ziptie? I'm trying to put fuel line over my tie for the fuel tank and I'm having problems. I hope I'm not the only one who has this problem. Any help or suggestions are welcome. Thanks
ollie 45 is offline   Reply With Quote
Old 10-26-2007, 05:05 PM   #2
Hellsavage's Avatar
Blow your nose and rub the zip-tie with it before trying
mzl Hellsavage
Hellsavage is offline   Reply With Quote
Old 10-26-2007, 05:05 PM   #3
baby powder or WD-40 down the fuel line should lube it up enough to slide with ease
vroom88 is offline   Reply With Quote
Old 10-26-2007, 11:31 PM   #4
rltanner's Avatar
I used good ol spit
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 10-27-2007, 06:02 AM   #5
Trader Rating: 27 (100%+)
WD40 and a set of needle nose plyers to open the fuel tubing to get the zip-tie started...
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 10-27-2007, 01:18 PM   #6
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Sounds to me like you are going about it the wrong way... do you already have the zip tie in place? If so, you've already messed up. You have to put it in place while you're assembling it.
Run the zip tie up through the slot in the tank lid, put the tubing on, make your loop and put the end back down through it... use ANOTHER zip tie on the bottom when you run the tip back through... Trim the excess length, and cut the other one off so it's just the little square end.
Don't try to form your loop and then slip fuel tubing over it. It's just WAAAY too difficult to be worth the effort. It isn't like zip ties are expensive! Cut it off and start over if you mess up.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 10-28-2007, 03:32 PM   #7
MadRacer's Avatar
Trader Rating: 33 (100%+)
I use zip ties with no problems.
I bought some chrome fuel line springs from Ofna and they seem to work great and ads some bling.
MadRacer is offline   Reply With Quote
extend fuel line nitroforce Singapore R/C Racers 2 08-20-2008 03:10 AM
long fuel line? hybrid_eg6 Nitro On-Road 1 10-20-2005 02:07 AM
gap with fuel in the line classic xl Monster Trucks 2 06-30-2005 03:50 AM
Fuel Line Filter?? 2Hard2Handle Nitro On-Road 20 07-30-2003 11:07 AM
Fuel Line Gundam Singapore R/C Racers 4 01-02-2003 10:28 PM
