Old 10-26-2007, 03:30 PM   #1
Default Proper way to jump?
I got ambitious and started taking my gas truck off a ramp for the first time today. After learning the hard way not to stop gunning the throttle after take-off, I began to get the hang of it. I was trying to experiment to find the cleanest way to land. A few times I heard a nasty glitch from my gears when I landed.
What is the rule of thumb for going off a jump, try and maintain the speed (speed is wrong, RPMs maybe?) you took off at?
Imperator is offline   Reply With Quote
Old 10-26-2007, 03:38 PM   #2
rossoh10's Avatar
You can control your rc when its in the air by using the throttle.If your front end is in the nose diving position you can pin the throttle to raise the front end up.If your front end is nose up you can tap the back brake to bring it back down...........I usually let off the gas right after I clear the jump.Depending on how the car reacts, depends on how I react..All I can say is practice practice practice......
rossoh10 is offline   Reply With Quote
Old 10-26-2007, 03:39 PM   #3
air8's Avatar
SHINY SIDE UP!! LOL. JK. On the race track as the vehicle (1/8th scale) lifts off the jump face I slowly let off the throttle so it lands front tires first on the down side, or all 4 tires on a flat landing. With my GT2 I have to let off the throttle before it takes off and stand on the brakes while it's in the air. It's a whole lot different than 1/8 scale.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 10-26-2007, 03:39 PM   #4
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
the thing that works for me is i keep the trigger where it is when i start jumping off while im in the air.
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 10-26-2007, 03:40 PM   #5
air8's Avatar
But if you built a quarter pipe shaped jump that shoots straight up,...well.. I think you're at the mercy of the RC gods.
--"U Ain't Fast!!"
Chris Pearce
Old 10-26-2007, 04:10 PM   #6
rossoh10's Avatar
Yes 8th scale is different for 10th scale.I race both truggy and buggy and must say they jump on there own...10th scale is a little different.....as for the gt2 I know a lot of people that have a problem whith keeping the front end down........
Old 10-27-2007, 05:42 AM   #7
joe of loath's Avatar
the firestorm has a problem with keping the front end up. no idea why, it's weight distribution is like a wheely king!
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 10-27-2007, 05:49 AM   #8
Trader Rating: 19 (100%+)
Coming from oval racing to offroad, jumping was the hardest thing. Fortunately, my cen likes to nose dive, so it's easy to just stay on the throttle to correct, occasionally it'll be nose high and a quick tap on the brakes brings the nose down. When learning to jump, having spares is the key.
pooldoc is offline   Reply With Quote
Old 10-27-2007, 05:53 AM   #9
It also makes a difference in the way you leave the ramp/jump. which is a handy tip to know, as in if you have problems with nose diving no matter how much throttle you give it in the air try leaving the ramp with a bit more gas than you would normally use. it becomes second nature after a while remeber the bigger the jump the more reaction time you have in the air. some makes or offroaders are more responsive in the air than others.
AndyM is offline   Reply With Quote
Old 10-27-2007, 09:06 AM   #10
try hit the part of the ramp that looks the most 'perfect', as if it is rounded like a speed bumb then you will definatley go nose down it should be curved concavely and be relativley smooth.
Old 10-27-2007, 11:39 AM   #11
just punch it!
mugenlife is offline   Reply With Quote
Old 10-27-2007, 11:46 AM   #12
exept for quarter pipes
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 11-01-2007, 05:18 PM   #13
DR ZAIRUS's Avatar
If you have a real nose-diving problem, you need more pack in your front shocks: smaller piston holes and thinner oil. Or if you want to make it easier just change to a bit thicker oil, but it will affect other things too.
Once in the air, you can help the nose go up by tapping on the throttle.
Land flat on the landing surface (be it horizontal or down hill) and without throttle, so you won't force the gears. Use throttle once you are safelly landed.
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
TEAM www.fisio-sport.com
(Valencia, Spain)
DR ZAIRUS is offline   Reply With Quote
Old 11-01-2007, 06:08 PM   #14
associatedguy's Avatar
Don't let off until you see god.
CEN Matrix FRE Buggy
Novarossi P5 with a 9886 pipe
KO Helios w/ spektrum
associatedguy is offline   Reply With Quote
I like to jump joeling R/C Photography 12 01-03-2010 02:15 AM
new jump dan.zinger Monster Trucks 6 08-13-2008 10:54 PM
Best jump... EVER. smb17 Nitro Off-Road 20 07-17-2008 01:21 PM
ae needs to jump on the bandwagon chuchurocket Nitro Off-Road 6 10-05-2007 01:53 PM
how high can u jump? tenpins77 Electric Off-Road 7 07-10-2007 09:22 PM
