Old 10-25-2007, 12:14 PM   #1
Casper's Avatar
Trader Rating: 33 (100%+)
Default .21 Drake Platnium bearings
Anyone know the case bearings sizes for the drake Platimum motors? I have a bearing going out and want to replace the bearings with ceramics but want to make sure I am ordering the correct sizes.
Thanks!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 10-25-2007, 02:53 PM   #2
22Racer's Avatar
Trader Rating: 67 (100%+)
I replaced one, I just put one from a Novarossi in it. Should be the same as a V-spec also.
Rex
22Racer is offline   Reply With Quote
Old 10-26-2007, 06:57 PM   #3
Peter Martin's Avatar
front is 7x19x6...rear 14x25.4x6
Peter Martin is offline   Reply With Quote
Old 10-26-2007, 07:45 PM   #4
Casper's Avatar
Thanks!
Old 10-26-2007, 08:12 PM   #5
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
I have this problem before and would look for after markey bearing but cant get the actual size on this rear bearing. someone is telling me that take out the bad one and measure it and buy back the same size as the old bearing OD area cant be wear out so measure and that is actual size bearing. By the way my engine is LRP Z.21R. I try to find the OEM of this engine but no luck. End up order original bearing from LHS.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 10-26-2007, 08:53 PM   #6
Send a message via MSN to rhymster
i have a trinity platinum and they are all picco engines. so any new picco will have the same spec's,, besides the sleeve if it is a draked!!!
rhymster is offline   Reply With Quote
Old 10-26-2007, 08:53 PM   #7
Casper's Avatar
I was looking for cermics to replace the OEM. Trinity does not list the bearings as replacements for this enigne as well.
Old 10-26-2007, 09:06 PM   #8
i know it is a picco case and sleeve and piston i promise you check there website out and you will have your answer
Old 10-27-2007, 06:53 AM   #9
22Racer's Avatar
Just go to www.amainhobbies.com, they have ceramic bearings (size listed above) Also try Tko at www.tkocompetitiondev.com
Rex
Old 10-28-2007, 10:09 AM   #10
Casper's Avatar
I could not find specs for the bearing size on picco's site or the trinity site. Picco just listed the bearings by part number and front bearing or rear bearing descriptions.
I bought some bearings from amain a couple days ago. They should be here tomorrow. Thanks for the help guys.
Cell master platnium aus jd 2703 Electric On-Road 2 12-01-2007 12:43 AM
NEW Orion Lipo 4800 - Platnium Edition wannabee R/C Items: For Sale/Trade 12 09-15-2007 03:41 PM
Trinity platnium fuel.... That0neguy Electric Off-Road 14 09-19-2006 11:55 PM
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 08:38 AM
XXXNT- dRAKE, Fantom Dual Chambered Pipe, Drake Pipe, Ofna Starter Box JubJub R/C Items: For Sale/Trade 2 09-30-2003 05:28 AM
