Old 10-29-2007, 05:19 PM   #16
Scottmisfits's Avatar
I'm running the Castle Creations regulator with an HT 1500mAh receiver. I don't think I'll ever go back to nimh in pretty much anything unless I have to.
Scottmisfits is offline   Reply With Quote
Old 10-29-2007, 05:39 PM   #17
mremtr's Avatar
I've been running Lipo's in my buggies now for almost 3 years ,and only had one minor incident,and it was when I dropped a pack right on it's corner on concrete! Can we say FIRE !! Yeah Buddy !! But IT went out the door before there was any troubles
For those 3 years I have been running a single Hitec 5995TG for steering and a 965 for throttle never had any issues at all ! Oh and I DO NOT run a regulator the servos are made for the 7.4 volts . Only thing that I should get is a voltage cut off device,but it might do the wrong thing ,right now my reciever seems to know when to go into failsafe so I think all is well .
Oh yeah the Spektrum reciever works great up to 9.6 volts
mremtr is offline   Reply With Quote
Old 10-30-2007, 05:55 AM   #18
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
FYI - The MuchMore and VXR regulators will output 6.4 volts to the RX. This will ensure you will not trip the failsafe of your rx. It keeps things nice and smooth for 1 hr and 10 to 15 minutes with my 1000 mah packs. They have been working flawlessly for quite some time.
I run Spectrum with my Air TX and Futaba servos.
Very small and light to boot.
TEX
tex1 is offline   Reply With Quote
Old 10-30-2007, 09:16 AM   #19
Does anyone know if the E-flite 2-3 Cell DC Li-Polymer Balancing Charger ( http://www.amainhobbies.com/product_...ducts_id/11575 ) will work on receiver packs? I know it's for planes but, I assume it'll work on a receiver lipo?
g26er is offline   Reply With Quote
Old 10-30-2007, 09:19 AM   #20
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
Do you guys use a balancer at all??? I have the new losi lipo receiver pack, and I am going to use my trubo 35 gfx with lipo upgrade to charge it, do I need a balancer?
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 10-30-2007, 10:22 AM   #21
MetalShield's Avatar
I definately will go LiPo, we run endurance race and Im tried of pitting for the batteries. hopefully the LiPo will reduce the pit time.
Calvin Mercer - MSPvideos
HobbyHobby Racing Team / XXXmain Inc.
MetalShield is offline   Reply With Quote
Old 10-30-2007, 12:16 PM   #22
Trader Rating: 51 (100%+)
Send a message via AIM to motoazure
I noticed the Much-More regulator is 7 amp and also 5 amp. I'm running the Pro-Tek 5 amp.
Anybody know how this affects the performance.
As I posted before I"m having trouble with the 3PKs either losing bind or going into fail safe. I wonder if I should run the 7 amp.
motoazure is offline   Reply With Quote
Old 10-30-2007, 01:40 PM   #23
Registered User
It makes no difference both will perform the same duty except the 7 amp one can handle more power 2 amps more to be precise.
This means it can handle more servo's, 5 amps is plenty for 2 digitals i would think.
I only have a 5 amp in my showtime and it has 5 digital servo's.
The 7 amp will have no effect on bind, try and keep your power leads away from the arial and receiver that is more than likely your problem.
Loop&Roll is offline   Reply With Quote
Old 10-30-2007, 06:35 PM   #24
griz11's Avatar
Send a message via MSN to griz11
Default Spektrum has a part for the failsafe problem
Spektrum has a capacitor they sell for electric cars to keep them from going into failsafe when the batt gets a little low and you hit it with a lot of load. I put on on my car and I haven't had a glitch since. I've used lipo on my Tx for over a year now and on the car for 6 mo or so with no problems at all after putting in the cap. The cap prevents spikes or transients on the power line to the Rx. Which can trip the failsafe. I too left one on at first and it was fried afterwards. Now I pull the one in the radio and unplug the one in the car so they don't discharge. No way I'd go back to nimh. One thing that isn't common knowledge about these batteries is that plain old salt water will neutralize them. If something happens and the case ruptures salt water will stop whatever is happening fast. Its also the recommended way to dispose of them. One of the reasons they went to this type of battery is that it can be rendered inert with salt water and so is much less of a pollutant when discarded. If you use the proper charger they are plenty safe. And I've seen a couple of 90+ mph bad wrecks at the drag strip where they flew completely out of the car with no damage or massive explosions
Griz
PRO MOtion FOtos
Racing Images
www.youtube.com/griz11 Photos are here www.pbase/griz11 www.elroyjetson.info
Canon 7D EF400 EF70-200 EF40 Tamron SP70-300
griz11 is offline   Reply With Quote
Old 10-31-2007, 06:56 AM   #25
tex1's Avatar
Thumbs up
Griz-
This is off topic. Are you going to be at the RC Pro Series finals? If so, look myself and Joe up in the Indy/T&T booth there at the show. Come by and say HEY.
Should be some pretty good racing there.
TEX
Old 11-16-2007, 06:57 PM   #26
sportssedanman's Avatar
Send a message via Skype™ to sportssedanman
I have an XB8EC with a Premium Power 1600mAh Lipo and the Much More 7A voltage regulator. I use a JR XR2i radio with JR125 receiver on 27MHz. It glitches like a MoFo!! When I take the radio 25m away, the throttle and steering servos (ACE D1015) go nuts! If I put a NiMh receiver pack in it, there are no problems. I also noticed that if I power the receiver using NiMh, just plugging the voltage regulator into the LiPo (neither of which are plugged into the car) causes glitching, but not as much.
I am getting a 2.4GHz Nomadio React in a few days. Will this solve this problem?
Anyone know how to fix this?
sportssedanman is offline   Reply With Quote
Old 11-16-2007, 09:11 PM   #27
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
I have the standard spektrum receivers, are they ok to run without a regulator or do I need one?
Air 94358 steering
Fut 9351 throttle
Dayton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 11-17-2007, 06:12 AM   #28
joe of loath's Avatar
sounds like the chip in the regulator is running at a rate that interferes with the radio. it shouldnt do it with the 2.4ghz but if it does try changing your regulator.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 11-17-2007, 08:55 AM   #29
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
A bunch of companies sell them, including Radio Shack if you can solder (will cost you about $5 total between the cap, pigtail and heatshrink).
This isn't a new concept by any stretch of the imagination. I have had one in my 12th scale cars for about 6 years now. In fact we were doing it before any companies even started selling them. It was a great way to keep your 12th scale voltage consistent through to the end of a race without having to spend the big bucks for a receiver pack (Which were very expensive at the time since they were tiny, loose, hard to get cells).
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Apogee 2S 2000mah Lipo receiver packs for sale C.Capelo R/C Items: For Sale/Trade 6 07-20-2008 06:27 AM
Lipo receiver packs wallstreet Radio and Electronics 0 03-17-2008 09:36 PM
Receiver battery packs, nimh and lipo K.Copeland R/C Items: For Sale/Trade 14 03-07-2008 10:17 PM
Lipo receiver packs mo Nitro On-Road 5 07-13-2006 02:21 AM
