Old 10-24-2007, 04:33 AM   #1
jono mad racer's Avatar
Send a message via MSN to jono mad racer
Default --*Set-up Tips*--
Hey guys,
I haven't seen a forum for set up tips so i thought i make one and see if it helps.
Get things going.
The higher the oil wat dose it do?
The lower the oil wat dose it do?
my set up for my hong nor buggy is
Front - 5000
Center - 5000
Rear - 3000
If i lower the rear or higher the fron what will that do??
Cheers,
Jono
Volkswagen Australia
jono mad racer is offline   Reply With Quote
Old 10-24-2007, 04:44 AM   #2
rabidsquirrel's Avatar
Someone post up some links to all the 'usual' good set-up PDFs...
rabidsquirrel is offline   Reply With Quote
Old 10-24-2007, 05:35 AM   #3
salteen's Avatar
Trader Rating: 90 (98%+)
I just got done changing the fluids in my RC8. It was set up as 5-7-3. I swapped out the front and center and it's now 5-5-3. I have only driven it in my yard so it's hard to tell how it's tracking now. We'll see once I get it to the track.
salteen is offline   Reply With Quote
Old 10-24-2007, 06:51 AM   #4
JeremyS's Avatar
if you need more turn in drop down in the front. this helps the diff act like a open differential. so the diff is not trying to overcome the resistance of thicker fluid so each wheel is then more independent from the other and can turn at a different speed to make the corner.
On a bumpy/rutted/blown out track going thinner in all the diffs will help smooth out the car, as each diff(front to rear) and each tire is working more independently.
if you are loose in the rear end drop down in diff oils....for same reasons....
V-8 For life
Blue Oval Loyalist
If you ain't first....your last
JeremyS is offline   Reply With Quote
Tips. Infamouz Nitro On-Road 1 02-09-2007 05:13 PM
Tips thecrow2k R/C Photography 1 05-09-2005 04:07 PM
DIY (Do it Yourself) /\ Tips /\ drive4fun Electric On-Road 11 04-23-2005 07:13 AM
DIY {Do It Yourself} TIPS drive4fun Nitro On-Road 6 04-18-2005 04:45 PM
Tips on what car to buy.. ownage Electric Off-Road 8 11-04-2002 04:21 PM
