Old 10-23-2007, 08:35 PM   #1
Crocket's Avatar
Questions?? O.S. Speed .21VZ-B V-Spec ......Alloy Head or Magnesium??
Hi all,
I am looking at buying an O.S. Speed .21VZ-B V-Spec motor and would like to know which would be the better version (Alloy or Magnesium).
Does anyone have either of these that could provide constructive feedback?
Please provide an explaination for your suggestion and not just vote for one or the other.
Thanks in advance.........Dave
Crocket is offline   Reply With Quote
Old 10-23-2007, 10:53 PM   #2
rossoh10's Avatar
One weighs more (al) and one weighs less for a lower center of gravity (mag).......
One disapates heat away from the engine better(AL) and one doesn`t(mag)........
rossoh10 is offline   Reply With Quote
Old 10-23-2007, 10:54 PM   #3
rossoh10's Avatar
oh yeah and the mag head bends easier
Old 10-23-2007, 10:54 PM   #4
rossoh10's Avatar
The al is around $50 cheaper
Old 10-23-2007, 11:24 PM   #5
I ran the original speed since july but with an aluminum head from one of my other V-Spec engines. I heard the temps are way high running the mag head so I ran with the aluminum version from break-in. The minor weight saving will be negated with dirt build-up as you run. The mag head sure makes for an expensive paper weight. I've had 4 V-specs, an Ebmod and then the speed. All are great with slightly different power delivery between them. There isn't a huge difference in power. The difference can be made up if you get a better drive out of a turn or have a slightly better setup. I remeber at our CORCS finals a guy with a Werks B7 pro walked the speed engine every time. My next engine will be a Axe Rossi Cobra Evolution X1. However, I'll have a Speed Al ready as backup since they are the most reliable engines.
Toycar5 is offline   Reply With Quote
Old 11-03-2007, 03:04 PM   #6
Crocket's Avatar
Thanks for all the feedback guys
Kind regards.........Dave
Old 11-04-2007, 11:25 PM   #7
RETRO RC's Avatar
hey Dave you gettin ready for the Nats aye
hamilton maybe running a meet on the 18th of december with the track changes completed heres a link to the nats web page for you
http://www.hrccc.co.nz/2007_nationals.php
also keep an eye on
http://www.franktonmodels.co.nz/phpBB2/index.php
for updates on possible race meet on the 18th nov
we had a run yesterday and the track changes aren't bad little bit tight maybe. shame we got rained off I was the only buggy to do a 34 sec lap and i'm still running in the motor
with the rest of the changes they're expecting about 39-43 sec lap times so it should be a good meeting.
now back to topic -Ali head for sure for the extra price of the mag head (especially when your talkin NZ dolars) any performance gain isn't noticeable
see you in December
Adrian
RETRO RC is offline   Reply With Quote
Old 11-16-2007, 12:52 AM   #8
Crocket's Avatar
Hiya Adrian,
Wont be able to make it for the Nats warmup this weekend. I'll have to get some inside knowledge on setups and tyres as the three 10 min organised practices is not going to be much time to get to grips with it, any tips will be gladly accepted. .
I have just managed to organise time off work for the Nats so will now be able to send off my entry.
Just checked out the photos of the Hamilton track, http://www.hrccc.co.nz/2007_nationals_pictures.php Wow...it's looking very good, cant wait to get out there.
Looking forward to catching up.
cheers.....Dave
Old 11-16-2007, 01:35 PM   #9
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Yeah... so skip those and buy the B7 Pro for less money!
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 11-20-2007, 04:52 AM   #10
Jerseyboy's Avatar
Busy running in my Speed with magnesium head.
What I have noticed is that the magnesium head is a better conducter of heat than the aluminium. I think some guys confuse this and say that it runs hotter.
I can definitely see the difference. The mag head heats quicker and cools quicker. I dont find the engine running higher temps generally.
The important part is the rate of cooling.
Definitely has an advantage over the stock aluminium.
Jerseyboy is offline   Reply With Quote
Old 11-20-2007, 04:59 AM   #11
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
The heat does not get transfered from the block to the head thats the problem with the magnesium head.Sure the head is cool,but feel the block it is wayy hot.Its a sick engine i love mine with the aluminium head.
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 11-20-2007, 03:16 PM   #12
agent 007.5's Avatar
Well all I can say is Ryan Mayfield is still using the mag head and is having great success with it so I'm sticking to my mag head.
agent 007.5 is offline   Reply With Quote
Old 02-11-2008, 05:00 AM   #13
lowey79's Avatar
I think that the issue with the mag head is being missunderstood, Magnesium is a better heat conductor than aluminium. Therefore, it will dissipate heat in to the air faster than an aluminium equivilant. The heat from the block is transfered to the head at same rate (as fast as the alloy block will allow) as any other engine, BUT, the head will transfer it to the air more efficiently than alloy so this is why the head stays cooler.....
Aircraft piston engines use mag heads for the same reason.....
lowey79 is offline   Reply With Quote
Old 02-11-2008, 05:31 AM   #14
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
The only problem I've seen is that the Mag. head breaks easier. I've seen several with broken cooling fins.
skeller is offline   Reply With Quote
Old 02-12-2008, 12:39 AM   #15
Smile
I think you are wrong about the magnesium head transferring heat better than the alloy head, if you look on the os site at the v spec with the alloy head it says the the alloy transfers heat better than magnesium.
Wayne Walker from Australia who is a Mugen factory driver has been running the ninja MRT engines both on and off road for the last 9 months and has replaced all magnesium heads with the latest MRT alloy heads. Mugen sent new alloy heads to the Australian distributor for all MRT motors sold, why would they do that if there was no problem.
Wayne won the New Zealand Nationals running a Ninja MRT with the new alloy head where all other drivers running MRT's still had the magnesium heads and most had tuning problems because the engines run to hot. I hope this helps with your decission.
Barry Walker
The Freak is offline   Reply With Quote
O.S. Speed 21VZ-B V-spec Aluminum or Magnesium josh_c Nitro Off-Road 4 06-23-2008 12:35 AM
OS Speed Magnesium Head V-Spec FOR SALE: mdrnizd R/C Items: For Sale/Trade 5 05-29-2008 06:42 PM
OS SPEED MAGNESIUM COOLING HEAD NEW O.S. V-SPEC VZB RC8 GTempleton R/C Items: For Sale/Trade 1 03-10-2008 11:57 PM
OS Speed 21VZ-B V-Spec (NEW MAG HEAD) pasadena_z R/C Items: For Sale/Trade 7 11-13-2007 09:46 AM
