Old 10-23-2007, 08:31 PM   #1
Cheeny23's Avatar
Default Piston Stuck
Well it seems my dad left some fuel in his engine and it gunked up and jammed the engine. So i was wondering what are some safe ways to free it besides taking it in which ill probably end up doing anyway but is there any ways you can do it besides that. Umm its a Losi XXX nt sport.
any help is appreciated
Cheeny23 is offline   Reply With Quote
Old 10-23-2007, 08:35 PM   #2
WD-40 that sucker down and it JUST might free up
vroom88 is offline   Reply With Quote
Old 10-23-2007, 08:39 PM   #3
try soaking it in some marvel mystery oil over night. me and my lhs owner tried this to an old O.S. motor that was gummed up. it actually worked. dont know if anyone else has ever tried this. first time i'd seen it done.
Redfox03 is offline   Reply With Quote
Old 10-23-2007, 08:39 PM   #4
Cheeny23's Avatar
ok so wd-40 is ok to use. k thats one thing i was wondering thanks
Old 10-23-2007, 08:42 PM   #5
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Take the backplate off and put some after run oil in, let sit for a few hours or over night (depending on how bad its gumed up.
Most likely the bearing are gumed up and the oil will loosen it up.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 10-23-2007, 08:42 PM   #6
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
the marvel mystery oil will work alot better than wd-40...plus after soaking it overnight empty the oil out and with the glow plug out heat up the block with a heat gun before turning over, the heat will help to loosen up the gunk...
Jason Halvorson is offline   Reply With Quote
Old 10-23-2007, 09:27 PM   #7
we had filled a zip lock bag with the marvel mystery oil and just put the motor in there. wierd thing is, it started to bubble a little. dunno what was happening, but the next day the motor was good to go once we cleaned it off.
Old 10-23-2007, 09:38 PM   #8
the bubbling was just the oil going into the engine and the air coming out...
Old 10-24-2007, 05:12 PM   #9
Cheeny23's Avatar
since i didnt have any marvel oil, i used wd-40 and put it in b4 i went to school, and when i got home, took the gp out and got the wd-40 out and spun the engine a lil bit and sure enough it started cycling. Runs pretty good now. Thanks 4 the help
stuck piston retainer clips raceblast Nitro On-Road 4 08-16-2008 04:53 PM
OS TZ .12 Stuck at TDC theBUZZ Nitro On-Road 44 12-01-2006 05:47 PM
Light Oil & Small Piston Hole vs. Heavy Oil & Large Piston Hole Rich Panganiban Nitro On-Road 2 01-26-2006 03:24 AM
Okay, Now I'm Stuck finny Australian Racing 8 04-18-2004 06:37 PM
OS .12 tr came stuck in TDC AE Racer Nitro On-Road 19 08-15-2003 10:22 PM
