Old 10-23-2007, 05:34 PM   #16
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i just bought a helios with spectrum, so it looks like its gonna be 1 to 2 years before i make a change...
Jason Halvorson is offline   Reply With Quote
Old 10-23-2007, 07:00 PM   #17
T493's Avatar
It is a very nice transmitter but i think the price is a little high.
T493 is offline   Reply With Quote
Old 10-23-2007, 07:05 PM   #18
i've got the 3pm fasst. but, if the 4pk comes to be like 350 bucks or so i might get it. it's a big might.
Redfox03 is offline   Reply With Quote
Old 10-23-2007, 09:52 PM   #19
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by Nitro$junkie View Post
Whoa, i hope it's an MSRP not the real price i really like the radio but i do hope they can still lower the price down a bit
buboy28 is offline   Reply With Quote
Old 10-26-2007, 08:11 AM   #20
spiti58's Avatar
does the 4pk have an adjustable steering wheel adaptor like the 3pk? just wondering i know that where i race alot of the people w/ the 3pk like the drop down steering wheel.
spiti58 is offline   Reply With Quote
Old 10-26-2007, 08:14 AM   #21
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
its better has a tilt function like the EX-10
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 10-26-2007, 08:17 AM   #22
The Futaba 4PK was only just released and drew a lot of attention from racers due to its rather unique look. The 4PK’s contemporary styling is not only unique, it’s extremely well balanced and ergonomic and because the transmitter only weighs 1.5 pounds, you won’t worry about hand fatigue all the way through a grueling main. Besides the repositionable wheel, you can also adjust the trigger location to fit your finger and programming pluses include 40-model memory, 12-character naming, super-sensitive 2048 resolution and a 4th channel that’s ideal for adjusting front and rear brake bias in monster trucks. And here’s the best part: the 4PK was designed from the beginning as a spread spectrum system, which means the 2.4GHz module is built in, a state-of-the-art receiver is included, and all of the incredible advantages of FASST system technology are at your command!
Click here for the full details…
Features
- Much consideration went into the design of the 4PK’s grip, which is slightly thicker to accommodate larger hands. Besides being lighter, the transmitter’s weight is well balanced for added comfort.
- Achieve perfect “feel” in seconds with the Advanced Positioning Adapter. You can drop the wheel down, move it left or right, even change the angle – a feature many drivers have requested.
- The trigger position can also be shifted by as much as 7 mm. This allows you to customize the radio for sharper response based on finger size.
- The redesigned keypad features a large 4-direction jog button for quick access and scrolling. Important functions can be assigned to buttons on the wheel housing to keep them within easy reach.
- Not only is the backlit LCD screen large enough for easy reading without eye strain, it’s also angled for instant viewing without having to tilt the transmitter.
- Because the 4PK was engineered from the beginning for 2.4GHz modulation, there’s no long, unwieldy antenna. Instead, the antenna is shorter and lighter in weight, folds down for easy storage, and pivots for optimum reception.
- No NiCd battery here – the 4PK comes with an 1700mAh NiMH pack that’s comparable in size, but with almost twice the capacity. That means about TWO HOURS of operation on a single charge – enough for the longest of mains and maybe even an entire weekend of racing!
- The included R604FS receiver features Dual Antenna Diversity (DAD) for reliability and security. Its compact size (1.54 x 1.02 x .55 inches) and weight (0.49 ounces) lets you use it in the tightest installations.
4PK System Overview:
- 40-model memory
- 10-character model naming
- 4th channel for brake bias, throttle adjustments, etc.
- 2 programmable mixes
- Assignable button, trims and dials
- Digital trims and dials
- Advanced Positioning Adapter (APA)
- Adjustable trigger location
- Backlit 128 x 64 white LCD screen with adjustable contrast
- Subtrims, servo reversing and EPA on all channels
- Fail safe
- DSC (Direct Servo Control)
- Exponential & Adjustable Servo Speed (Steering/Throttle)
- Up/Down, Lap & Systems timers
- 100-lap memory
- ATL (Electronic & Mechanical)
- Traction Control/Acceleration Rate
- ABS braking system
- Boat mixing
- Idle-Up
- Tx NiMH and Dual-Output Charger
4PK Specifications:
- “New Driver”, “Race-Ready”, “Expert” and “Big Car” menus that add functions based on driving skill level and experience
- Throttle Mode Select, for selecting acceleration/brake servo neutral points between 70/30 for nitro or 50/50 for electrics
- Vibrating alert system
- “Direct Select” single-button access to eight preassigned functions
- Navigation Lap Timer that sounds when target lap time is exceeded
- Servo Display Screen shows set-ups/mixes for individual servos (Expert Menu)
- Throttle programming options, including 5-point curve, Expo and VTR
Futaba
Mugen
Novarossi
Byron's
Old 10-26-2007, 08:35 AM   #23
spiti58's Avatar
thanks. i missed that when i read the other posts.
"U Ain't Fast!!"
"Thats how i roll, fast and out of control, nothins gonna slow me down! except mabye the occasional pipe."
Old 10-26-2007, 08:48 AM   #24
rabidsquirrel's Avatar
Redfox,
I agree. I just have the plain 'ole 3PM, but the 4PK is going to have to hit somewhere around $325~350 for me to purchase it.
Radios should evolve like Personal Computers. Performance and Features go up, while the prices come down...
That's how I see it.
I'm a Futaba man, but there are features that I'd really like to see on this to give it a longer product lifespan, such as software 'modularity' (If there's such a word). Nomadio has pushed the industry much closer to a 'software' driven radio, as opposed to a hardware driven design. Military and some civilian radios are pretty much software driven designs. Nomadio has been building military radios for a while, and so they had some expertise in this area when they persued development of a Hobby radio system. They are showing a lot of promise.
Some of the Telemetry features will probably be 'must have' items on future systems. I'm kinda surprised that they aren't already, to tell the truth.
Almost every other type of racing has some proven telemetry systems out for consumption. RC should've been ripe for this years ago, given that you're allowed to have Rx/Tx to and from the vehicle due to the nature of the sport...
It'll happen. I'm just impatient...
rabidsquirrel is offline   Reply With Quote
Old 11-02-2007, 01:59 PM   #25
ShotGunn's Avatar
Nice
ShotGunn is offline   Reply With Quote
FS: Futaba R203HF HRS Micro Receiver + Futaba Transmiter FP-PK-FM RF Module 75MHz WogBoy Australia For Sale/Trade 4 11-22-2015 01:56 PM
FS: Futaba R203HF HRS Micro Receiver + Futaba Transmiter FP-PK-FM RF Module 75MHz WogBoy R/C Items: For Sale/Trade 0 08-27-2006 11:18 PM
Futaba HRS 75mhz recevier - Futaba Digital servo s9451 - Novak cyclone esc 4SALE alltech R/C Items: For Sale/Trade 11 10-14-2005 06:15 AM
Futaba 3PDF FM Pistol Radio, Futaba FP-R133F FM 3 Channel Receiver, FM 66 xtal 403forbidden R/C Items: For Sale/Trade 16 05-19-2004 08:34 PM
Futaba 3PK $260, Futaba R203HF $80, R113IP $75, Futaba $9450 $80, OS 12TR $135 smash123 R/C Items: For Sale/Trade 2 02-13-2003 03:03 PM
