Novarossi 367
One of the better and more experience drivers at the our track bought a brand new Novarossi 367 and was very happy with it, but it lasted only a race. It wasn´t too hot but the bearing gave out.
I was thinking about getting one but would like to hear other stories about this engine before making a decision. Got any? |
Front or Rear bearing? Just curious...
That's an expensive bit of kit ruined by a ~$5 part! :flaming: |
Rear, the kit brings extra bearings, but normally you dont change the bearings after just the break in.
Cota,
So, I take it that the motor survived the premature failure of the rear bearing? I guess he heard it and shut her down before any real damage could be done... |
get the boca 14.5 x 26 mm steel 9 ball bearing as soon as you get any of the plus line of engines , i think that novarossi had a bad batch of bearings from the manufacturer of the bearings . cost for the bearing is about 25 - 30 $ and then you have to find somebody who is experienced to put it in for ya :nod: pm me if interested i am very good with engines :nod:and run houstons engine service here locally in the northwest :nod:
later , houston novarossi is quite aware of the flame out issue and they are dealing with it for sure:nod: one way to deal with flameout issue is to add one more thin copper shim that comes with the engine to release some compression :D thats what we had to do to truhes engines to get em to run right , after we did that , they were too dam fast , :eek: seriously !!! another thing to do on those is to try a medium or hot turbo plug (turbo buttonhead part#nov28002)or try a medium or hot standard plug such as novarossi 6 or 5 plug , tames the beast down so it is useable power:nod: |
i have one and lets just say its great when it runs
get a v-sepc cheaper and better at everything overall just dont get the plus-2 367 |
i got one and love it.. the only problem i have is it flames out after i feel it up in the mains... but i talked with fusionmotorsports and they said its a tunning issue... if i was to buy a new motor id go with a c6bbt... inless i quit having these problems.. if it does it this weekend ill be buying c6bbt...
Originally Posted by houston
(Post 3790288)
later , houston novarossi is quite aware of the flame out issue and they are dealing with it for sure:nod: one way to deal with flameout issue is to add one more thin copper shim that comes with the engine to release some compression :D thats what we had to do to truhes engines to get em to run right , after we did that , they were too dam fast , :eek: seriously !!! another thing to do on those is to get rid of the turbo plug and try a medium or hot plug such as novarossi 6 or 5 plug , tames the beast down so it is useable power:nod: |
You must have had some bad luck. I ran my Hot Mods 367 for a whole weekend on a rushed break-in without any flameout or other issues. Oh the joy of nitro motors.
I believe that Hot Mods replaces the bearing as one of the mods, our is standard not modified.
my 500 dollar 367 is a flameout hero at about a gallon. using sidewinder30% wc blend. ive added the .1mm head shim and every nova plug from the seven to the 4. only had a little luck with the oddonnell 77 plug.just ordered a picco evo 2. only four more races in my area left and i need to finish one:flaming:
The 367 is a HEAP ! I have never seen an engine with so many issues !!
I know I have experienced it first hand! I love NovaRossi and run their engines faithfully ,but I won't give that 367 trash can room !!! It is as cantankerous as it can get ! I'm trying to figure one out as I type! Why is this thing eat plugs, have no bottom end, run hot ,then cold ?? I changed out the bearings and found the front one wasted and the rear one had shavings behind it as it was pressed into the block ???? Come on NovaRossi ?:flaming: Maybe this is why Truhe runs P5's now ? What ever he runs I will tell you this , Is SPECIAL NovaRossi WELDS the back plates on so you can't see what has been done with out a serious bunch of trouble !! Mike's engines were all welded shut this weekend at the Worlds warm up ! |
exactly my symptoms ...runs fat till you lean it more ever so slightly till no power and its 322deg:cry:
anyone one of you guys want to sell your 367s?
Originally Posted by mremtr
(Post 3811987)
I know I have experienced it first hand! I love NovaRossi and run their engines faithfully ,but I won't give that 367 trash can room !!! It is as cantankerous as it can get ! I'm trying to figure one out as I type! Why is this thing eat plugs, have no bottom end, run hot ,then cold ?? I changed out the bearings and found the front one wasted and the rear one had shavings behind it as it was pressed into the block ???? Come on NovaRossi ?:flaming: Maybe this is why Truhe runs P5's now ? What ever he runs I will tell you this , Is SPECIAL NovaRossi WELDS the back plates on so you can't see what has been done with out a serious bunch of trouble !! Mike's engines were all welded shut this weekend at the Worlds warm up ! later , monty |
