Diff. Shim????
Diff. Shim????
Hey just a quick question and if anyone could answer this quick please:If your shimming a diff. where do you put the shim?Diff. is from a Mugen Prospec Buggy?Also the shim is thin with a big center right?
You put the shims behind the gears as where the shim will be between the diff case and the gear
OK BUT DO YOU PUT IT BEHIND THE WASHER?
Dont think u should have any washers there should be four shims one for each side of the gears and that should be it!
UH YAH THE ONES THAT GO OVER THE O-RING.
