Old 10-17-2007, 08:33 PM   #1
jbish4's Avatar
Default Tuning tips for O.S. VZ-B???
just picked up an O.S. VZ-B. wondering what the best break in procedure is for it. also wondering if anybody has any tuning tips or needle settings for the hot south florida climate. what temp is right for this engine. also what is the best plug to run with this engine. any help is appreciated. thanks.
jbish4 is offline   Reply With Quote
Old 10-17-2007, 09:02 PM   #2
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
I've followed the OS break-in procedure with good results. Nothing exotic required.
After break-in, try setting the low speed needle at 3-3/4 turns out from bottomed out, and the high speed needle at 2-3/4 turns out from bottomed out. Set your mid needle flush with the housing, then turn it clockwise until the screw slot points at 2 o'clock when looking at it as its mounted in the car.
Good plugs are either OS P3s or O'Donnell 97Ts.
Temps over 260 would start to be worrying, but if you just tune for smoke and performance, that motor should rip at about 200 degrees.
Good luck with the motor! I love the two I have!
SkarTisu is offline   Reply With Quote
Tuning Tips and Guide razor_clawzz Malaysian R/C Racers 2 02-04-2008 07:28 PM
Engine tuning tips zardoz Nitro Off-Road 6 07-13-2007 07:28 PM
Tuning Tips. sl4ppinb4ss3r Electric On-Road 21 07-13-2006 03:35 PM
mp 777 sp 2? looking for any tuning tips gabbyb3 Electric Off-Road 2 03-05-2006 05:10 PM
New Build & Tuning - Tips Pls :) joshb Australian Racing 9 12-20-2002 10:42 PM
