Old 10-14-2007, 07:58 PM   #1
hiliter03's Avatar
Default shock towers????
Does anybody know where I can but CARBON FIBER SHOCK TOWERS fot a mugen prospec?
hiliter03 is offline   Reply With Quote
Old 10-14-2007, 08:42 PM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
warning i found they broke very easy...
Jason Halvorson is offline   Reply With Quote
Old 10-15-2007, 05:09 AM   #3
TeeKuang's Avatar
yeah, carbons are quite brittle.
Best Regards, Tee Kuang
Rovan 290S
Killer Bee Kill switch | Outerwears | hydraulic brake | Ace DS-1015 |ADA Rear billet hub bearing carrier | Hostile Nightmare MX | RCMOD Closed clutch |
Gasoline POWER : Malaysia Large scale hobby
TeeKuang is offline   Reply With Quote
Old 10-15-2007, 11:44 AM   #4
RACING MASON's Avatar
Send a message via ICQ to RACING MASON
Carbon does no have any flex in it wich cuses it to crack easer than you would think.
R.C. SYNDICATE RACING
Lake Havasu City AZ
Slash
Revo
CEN Matrix TR FRE
RACING MASON is offline   Reply With Quote
Old 10-15-2007, 01:45 PM   #5
rltanner's Avatar
Yup you should see Masons wing
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 10-15-2007, 01:56 PM   #6
captain america's Avatar
What evidence would you provide in support of your claim?
FYI, Formula 1 teams have been using carbon-fiber suspension blades with built-in flex points in stead of mechanical hinge joints for several years now. You would do better to do your research before making such claims.
captain america is offline   Reply With Quote
Old 10-15-2007, 02:48 PM   #7
Formula 1 teams
F1 is about money, they spend millions of dollars to build cars, then throw a car away if its a tenth too slow. apples and oranges
derricklong38 is offline   Reply With Quote
Old 10-15-2007, 03:22 PM   #8
The cured properties of carbon-fiber, using identical weave, layup, epoxy and number of layers, will have the same cured properties in the hands of an R/C enthusiast as it will in the hands of an F1 engineer.
R/C enthusiasts will throw away or liquidate a perfectly good buggy/engine/radio just to get the latest equipment in the hopes that they might shave a tenth off their lap time. Sounds like the same thing to me.
Old 10-15-2007, 05:06 PM   #9
Rattlesnaker's Avatar
Are you refering to the "flexures" used on suspension points? I believe they are titanium?
Also there are many diffferent ways to lay up carbon fibre, in regards to weave pattern, resin, etc. I don't believe that the same guys that design, engineer and build F1 composite pieces, are going to be the same guys that are designing and building carbon pieces for r/c shock towers, they would be very expensive shock towers!
FYI I work in the composite industry
Rattlesnaker is offline   Reply With Quote
Old 10-15-2007, 05:21 PM   #10
Trader Rating: 47 (100%+)
Check out A-Main Hobbies,they may have them. I run the Vertago
carbonfiber shock towers on my CRT and have had no problems.
They have came away from some realy bad crashes without
any cracks or splintering. Remember to seal the edges with some
thin CA and they should last forever.
rageworks is offline   Reply With Quote
Old 10-15-2007, 05:44 PM   #11
Some F1 teams have likely used titanium, but B.A.R (now Honda), McLaren and the Williams team used carbon through & through. An explanation provided by one of Williams engineers during a face-to-face discussion was that they had attempted a titanium/carbon hybrid, but that vibration and stresses were causing delamination at the point where the metal met the carbon, so they went with straight carbon. I was able to confirm this upon inspection of a broken suspension arm.
True, F1 teams use more twill & satin weaves, whereas most R/C components we see are plain weave, but the basics are still there. You can argue that the plain weave won't have the same strength as a satin or twill, but then, an R/C buggy won't be subjected to the same loads as a full-sized racing car.
With regards to your argument that F1 people don't design R/C stuff, Cecil Schumacher is proof that you're wrong: he was an F1 engineer that carried over his racing experience to the hobby industry. In fact, Schumacher's first ever 2wd buggy, the Top Cat, was probably the first ever commercially-available R/C car to adopt the inboard shocks/pushrod... Carried right over from Formula 1
Old 10-15-2007, 06:04 PM   #12
hiliter03's Avatar
I CAN GET A REAR CARBON SHOCK TOWER BUT I CANT FIND A FRONT ANYWHERE???????
Old 10-15-2007, 06:08 PM   #13
..maybe they are all broken? lol!...sorry couldn't resist
Old 10-15-2007, 06:09 PM   #14
thanks for the insight, captian america
Old 10-15-2007, 06:23 PM   #15
annie_himself's Avatar
Send a message via AIM to annie_himself
Amainhobbies.com should have what you need.
annie_himself is offline   Reply With Quote
ZX 5 SHOCK TOWERS HEAT Electric Off-Road 16 11-10-2007 09:52 PM
TC3 shock towers Larry B Electric On-Road 6 04-27-2006 01:09 PM
SHOCK TOWERS Hicksey Electric Off-Road 1 02-08-2006 07:25 PM
PRP shock towers for an xxx-s Wicked R/C Items: Wanted to Buy 2 05-07-2005 12:33 PM
TC3/TC4 Shock Towers??? Chris08527 Electric On-Road 2 02-14-2005 06:26 AM
