Old 10-14-2007, 06:22 PM   #1
Send a message via MSN to DirtRacer
Default ModelEngines 1/8th&1/10th starter Box HELP
ive just been trying out the starter box and have not had much luck in grabing the flywheel perfectly, ive tried checking weather the engine is sitting to high, or if the buggy is sitting the wrong way as well as the position of the starter wheel and the whole its sitting in,should the flywheel be sitting in the middle of the space of the chassie or a bit further back??
so far the starter box wheel has been from observation touching just after where the flywheel is,, my flywheel is currently sitting further back from the middle and the starter wheel just goes past and instead touching the chassie, has anyone used this starter box?? these guys being the maker of the GV rex-x ....
im currently useing 2x 3000mah batteries and useing a cable based charger , charging them for about 30min , considering that it takes 15min for 1800s ro charge.
RollingDist46
extreme sports and more....
www.myspace.com/m1urathanedist46
www.myspace.com/renegadebearingsdist46
DirtRacer is offline   Reply With Quote
Old 10-15-2007, 12:27 PM   #2
DR ZAIRUS's Avatar
Default box
The flywheel should be aprox in the middle of the chasis slot, so the starter wheel can grab it. You need to re-adjust the car's motor mounts, but make sure that doesn't cause trouble with the clutch bell alingning with the transmision gear.
If this were the case, you could try cutting (dremeling) the chasis slot wider, towards the side where the flywheel is. It sounds terrible, but won't hurt....
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
TEAM www.fisio-sport.com
(Valencia, Spain)
DR ZAIRUS is offline   Reply With Quote
Old 10-15-2007, 12:32 PM   #3
RACING MASON's Avatar
Send a message via ICQ to RACING MASON
+1
R.C. SYNDICATE RACING
Lake Havasu City AZ
Slash
Revo
CEN Matrix TR FRE
RACING MASON is offline   Reply With Quote
Old 10-15-2007, 01:59 PM   #4
rltanner's Avatar
I've got the Ofna crome top starter box and my problem i've been having is the plastic is melting on the thing that pushes down to start the motor it is melting and im not getting contact good enough to turn the car over but Ofna sent me another one so far I have'nt had a problem yet I need to make the flywheel hole in the chassie alittle bigger because the wheel on the starter box touchs and rubes on it
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 10-15-2007, 05:03 PM   #5
jumpjunkie's Avatar
I had this issue and it was all alignment. Take the motor out so you can see the starter wheel through the chassis. Then you can set your pegs so they are perfect and the wheel rises dead on in the center. Also, from this angle, you will be able to see if it is actually hitting the chassis once it is centered up. After that decide if you need to shave the chassis a bit.
jumpjunkie is offline   Reply With Quote
ModelEngines 1/8th&1/10th starter Box HELP DirtRacer Australian Racing 4 12-04-2007 09:06 PM
STARTER BOX 1/10th jimlazaro R/C Items: Wanted to Buy 3 12-23-2006 06:54 PM
WTB: 1/10th STARTER BOX jimlazaro R/C Items: Wanted to Buy 1 11-18-2006 03:42 AM
1/10th universal starter BOX dan-o R/C Items: For Sale/Trade 5 05-20-2005 03:16 AM
F/S 1/10th Scale Starter Box GalxzFlr R/C Items: For Sale/Trade 3 08-13-2004 03:57 PM
